I don't really know about the availability of fiberglas body parts for your 66, I have only seen parts for mine and some other more popular cars, I wasn't really looking, If I remember the link and get bored I will will search and see if there is anything available for you and give you their link through a PM.
I would recommend the 4.10 gear ratio in this case, it will raise the RPM's to a more acceptable level to get you the ET's you are looking for, to get in between the gear ratio's you stated, you can play with tire sizes a little bit to get in between those ratio's but really not all that much with the tires you need to keep some decent traction. I would completely forget the mention of the Southside Machine bars, they went out of business a couple years ago and there was a HUGE write-up on Maliburacing.com and the owner of the company even became a member to help out, and things just flopped for that company all together, I would do a search over there to see what some of them are using, and some of the recommendations I made are from what I read over there, as those guys are in the know for the amount of guys running the 78-87 A/G body cars on the track. |
I have run the McCreary street slicks. They require a burnout to get them soft. When you get them working right they will have fine cracks across the face of the rubber like slicks, like they are rippin the pavement. Drag radials will work better though. The McCrearys are air pressure sensitive. Do some hard starts on clean pavement and adjust the air until you get a uniform patch of rubber.
The guys I know that run Buick GN turbo cars get 1.60 60' times on slicks and drag radials. The cars are heavy enough that you don't have to worry about weight transfer. Just try to limit front end lift so the energy is converted into forward motion instead. |
| Better 60' times | oldsmo | Hotrodding Basics | 0 | 03-22-2006 07:22 AM |
| poor 60ft times HELP!! | bowtienut | Engine | 48 | 07-19-2005 09:58 AM |
| Welding Dana 60 | D200Dodge | Transmission - Rearend | 5 | 02-05-2005 08:30 PM |
| 60 foot times | KeithB123 | Engine | 4 | 01-06-2004 10:55 PM |
