better to build? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2010, 06:15 PM
better to build?
if given the choice, what would yall rather build up?
and which one would give me more bang for my buck?
1973 (400 c.i.d.) #481988 which i can get for $200
or
1973 (455 c.i.d.) #485428 which i can get for $300
both are Poncho motors and complete from intake to pan
the guy said both come with 4x heads
Old 11-06-2010, 06:23 PM
mud.man.rj's Avatar
which one huum
You know if you are going to spend the 455 will rule over the 400 in word and cubic inches. Both pretty much fit. Good luck choosing. But torque rules for fun.
Old 11-06-2010, 08:48 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If you are building a street engine, go with the 455, there's no substitute for cubic inches! If you are building a race only engine and plan on 650 hp or more, go with the 400 block because there is more iron between the crank and the cam due to the smaller main journals. If you are building a race only engine, I would highly recommend using an aftermarket block.
Bill
Old 11-06-2010, 09:23 PM
what i want to build is cruiser with the occassional drag. mostly just to beat the crap out of all the ricers around my area. although there is a 69 chevelle and a 68 camaro that i want to whomp on just to show poncho power, but like i said i really want a bad *** cruiser with some serious torque. i was thinking of 3.73 gears and a 200-4r tranny, tell me what you think, and any ideas of what to put in the motor, i.e. crank, pistons, bore size, intake, heads, etc...
Old 11-07-2010, 12:00 AM
WDCreech's Avatar
A 455 would probably do the job, but if you need to push the horsepower, I'd go woth the 400 block with an aftermarket forged stroker crank with aftermarket forged rods. I would have the block sonic checked before boring more than .030". Being that you're in South Carolina, you might want to get hold of Jim Butler in Tennessee; http://www.jbp-pontiac.com/ He builds a hell of a Pontiac and probably can supply everything that you might need. He could even supply you with an aluminum Pontiac block, if that is what you wanted and his service is great!
Old 11-07-2010, 07:39 AM
yeah im trying to stay as cheap as i can but still get plenty of horse and lots of torque, say maybe 500hp which shouldnt be too hard
Old 11-07-2010, 05:39 PM
Well I bought the 455. Its got some rust in the even cylinders so its seized but it's not too bad and its standard bore. I was planning on going 60 over anyhow. The Guy even lowered the price to $250 and threw in a 4bbl q-jet. Who am I to pass it up
Old 11-07-2010, 09:18 PM
WDCreech's Avatar
Before you bore it .060, you had better have it sonic checked. I had a 455, a few years ago that would only go a max of .030 without filling the block.
Old 11-08-2010, 05:28 PM
yeah i opened the motor up today. your all going to say "lol classic" i found Oily the mouse ad one of his buddies in the pan. the #8 piston was in there pretty good but i eventually got it out. there is some rust in the bores, but its not too bad. you can still see the cross-hatch so to agree with you yes im going to have it cleaned up and checked first. one of my buddies also recommended only going .030 over as well. the only reason i was thinking of .060 was to get my 1:1 stroke/bore. but all said the block is in great shape. i will get the measurements later but the crank is in great condition and doesnt look like its ever been turned
Old 11-09-2010, 12:33 PM
Before you get too deep in this build you need to figure out what heads you are going to use. I built a 461 out of a 68 400 block and ran out of money to get a good set of heads so I just but the stock 6x-8 heads on it to get me by. It probably only made about 350-370 horsepower and around 450ft/lbs. It was fun but you would not really have at beating a really good small block or bbc without good head combo.
Old 11-09-2010, 03:28 PM
well right now i have two choices for heads, i can either use my 4x-1H which i cc'd at 112cc or my 6x-8 heads which i havent cc'd yet but supposedly come in at 98 cc's. which ones would yall reccomend? i could buy a set of rpm's but i wanted to use that money for a new rotating assembly
Old 11-09-2010, 04:27 PM
WDCreech's Avatar
With the 4X-1H, you still have a smog engine and it won't be very impressive. The 6X-8 will be slightly better. Best bet would be to keep looking until you find a pair of 5C-4 or 5C-7 (best), or 4C-5 or 46, or 6X-4 or 6S-7. The 5C heads have screw in rocker studs, the 4C and 46 heads will have screw in studs if they were cast after April '73 (Dxx3). There may be exceptions, so be sure to check. Most 6X or 6S heads will have pressed in studs, so again, check.
Bill
Old 11-09-2010, 04:38 PM
ok thanks creech i will keep an eye out. and if any of yall have some, hollar at me
Old 11-09-2010, 06:48 PM
I have a good question for you? What is the fastest car you have ever driven? That would give me a better understanding of what you are looking for as far as performance. I would like to share some of the pitfalls that I went through building my 461. I am from the aiken area so I can try and lead you in the right direction. What is your budget for this build?
Old 11-09-2010, 06:59 PM
Onefunponcho's Avatar
Bill
I have had both 4x and 6x no 4 heads in my past and they all had screw in studs factory. Not sure if this is uncommon but its just how my three pair were, However they had a fine thread on the stud and aftermarket lock nuts where hard to find for them when you went to roller rockers
Planning 434 build for mud drag s10, need help plutonium233 Engine 21 08-06-2010 10:27 PM
540 BBC build Biscuit6447 Engine 57 04-15-2010 07:47 PM
383 build looking for opinions 48Frankin Engine 13 03-08-2010 05:08 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
