CNC, is there a reason why nobody seems to dowel the maincaps to keep them from moving? I know Smokey Unick mentioned this in one of his writings. Many of the aftermarket rods have dowels for alignment and with straps or a girdle I think it might be a cheaper alternative than billet caps?
blocks
The problem with installing the dowels is all the time you would get into the perfect alignment and sizing to make them worth while.
I can agree somewhat, Carl on the longer stroke cranks and the loads they impose. I have seen blocks with cap walk but, none of them seam to have a real big effect on the bearings... what have you seen as far as cap walk and bearing issues on the 400 hp ish street engine???? I have a hard time getting these typ of engines back into the shop for maintenance. It's the old it's not broke don't fix it syndrome. Keith |
A lot of the blocks I see are 350s (two and four-bolt) that have been subject to detonaton, so the ability of the owner to tune his engine comes to play here, also. The difference between installing splayed caps on the roller block (two-bolt) and retrofitting the older block (four-bolt) for a roller set-up is probably a wash, with the splayed caps block getting my preference. A 2 bolt block with studded mains and TIGHT registers is probably good for 450 HP or so, but the tune comes into question again. I like to err on the side of safety, but a two-bolt block will hold up to most street use as long as it's not too radical and is tuned properly. The added stroke of a 383 is certainly something to add to the equation and a 4 bolt would probably be the choice.
But all the engines I have built for myself latley have been four-bolts. But then againg I have a lot laying around to pick from....... tom |
The SBC has a weak webbing to begin with and drilling or machining extra hole in the main cap area makes for weaker link. The problem with the GM 2 bolt cap is there is not much surface area where the cap sets in the register. Now if the 2 bolt 350 blocks were as wide as the 400 2 bolt register then you could put some power to them. |
Guy's I gotta agree with carl, I have ran 2 bolts at pretty insane power levels of up to 550hp.BUT! This was in claimer dirt track applications where we knew it was a grenade with the pin pulled going in.Some lasted some didn't.On any thing I wanted to last a 4bolt would definitely be preferable and if pushing past 500 real hp I would say splayed mains are a very wise choice.I'm no machinist but build my own engines and get to pay when they go boom.We usually say it is not a matter of if it will blow but when will it blow. But when your racing in a class where $500.00 will take your engine and you want to win you do what you gotta do.
theres some good info on this board, but tom your about my age, and you say and explain things in a way that makes a lot of sense to me. you a asset to this board. |
I just wanted to chime in on this discussion be cause I've got the opposite problem. I have a 2 bolt 010 block that is fresh from the machine shop and a 4 bolt roller block that is somewhat fresh. You can still see the cross hatch pattern in the bores! But the heads that were on it were cracked and I haven't had the block checked yet.
I'll be ordering my stroker kit next week. I've already purchased a Crower solid roller and cut away lifters. P/N 00426 .570/.584 with duration at .050 250/252. I plan on running my SR torquers (I bought them before I bought this car) and running my old Offy dual quad tunnel ram with 390's. I plan on using the 4 bolt block if it checks out. |
Again, thanks to everybody for the input. I think I'll likely just play it safe (and cost friendly) and use the 4-bolt with a hydraulic flat tappet setup, and be extra careful breaking it in.
| Gen 1 small block roller conversion with GM rollers | camaro freak | Engine | 2 | 07-27-2007 11:50 AM |
| Roller block | zeker6 | Engine | 1 | 03-31-2004 05:28 PM |
| Removing fenders? | Jag Daddy | Body - Exterior | 3 | 11-26-2003 04:42 AM |
| Roller or flat? When is a roller needed? | killerformula | Engine | 3 | 11-10-2003 03:58 PM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
