Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Better core block for sbc 383, 4-bolt flat or 2-bolt roller?
Old 02-06-2008, 07:36 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
I would go with the Vortec roller block. I stopped using flat tappet blocks a long time ago. If you use the Vortec block make sure you use the timing chain for Vortec engines by Cloyes, if not, a standard timing chain will contact the block, been there done that.
