Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Better core block for sbc 383, 4-bolt flat or 2-bolt roller?
Old 02-06-2008, 02:31 PM
rreruption rreruption is offline
the roller block def on the 2bolt caps that all depends on how much engine youre going to be running what cr,and cam and what not.I would say take your 4 bolt caps off your other motor and have them machined to fit on your vortec block,get a kit from scat for your 383.If you can 6" rods are better but dont use any less than 5.7" rods.If this is going to be a highway cruiser I'd stick lower cr like about 9.5:1 with an .043 head gasket and a smaller cam like a 270hr magnum cam,A performer intake with a 650 holley vacuum secondary,and headers you dont really need more than a 2.25" exaust pipe.I would suggest a good bowl job,backcutting the exaust valves,and having screw in studs and guides installed.
383ci 9.5:1
Vortec heads
1.52 roller rockers
270HR magnum comp cam
double roller timing chain
Performer or cyclone intake
650cfm holley or Q-jet 750cfm
headers long tube
X-pipe 2.25"
50 series df flowmasters or youre prefence some like the dynomax super turbo
