Better launches with HD springs?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2009, 04:01 PM
406chevelle's Avatar
One of these days...soon
I need to replace the rear leaf springs (5 leaf) on my daughters 78 camaro which is used as a mile track car and some street use.
I believe the Heavy Duty leaf springs give the same ride height as the standard springs but the ride is not as smooth.
It has a 400sbc (approx. 450 HP 480TQ) TCI TH350 auto trans with 3000 stall and 4.10 gears and posi.
My question is will the stiffer springs get MT drag radials to stick any better??
406chevelle
Old 03-02-2009, 11:03 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
How does it launch now? Are you hitting the bump stops on hard launches and then the tires go up in smoke? Is wheel hop a problem?
Old 03-03-2009, 10:34 AM
Actually the 400sbc is not in it yet, I am anticipating a traction problem. One of the leafs is broken and the springs overall are shot so I need to replace them and want to replace them with the best option.
I am also going to install a pair of the Jegster Lift Bars and Jegster frame connectors.
http://www.jegs.com/i/Jegster/550/41044/10002/-1
http://www.jegs.com/i/Jegster/550/40052/10002/-1
Old 03-03-2009, 10:45 AM
edit: you added info before I posted this
anything is possible but stiffer springs means less weight transfer to the tires at launch...
I'd make a "helper" stiffening leaf and test that at the strip for results first...
for what it's worth, food for thought:
I used old soft springs on purpose with no lift movement restriction on the front (loosened the sway bar, rubbers in the coils etc) for max quickest weight transfer at launch....
mounted rear shock coil helper springs that were loose at the top, just contacting the floor at the top...
the coils only added spring rate to the car when 2 people were in the back seat or crossing really rough RR tracks...
(drove very nice on the street)
I did try adding shims to the coils tops to increase the spring rate and/or tried helper leafs in combo's to see if new springs would be better and the answer was no....
every car is different, all you can do is test till you find what it does like best..
adding spring rate is easier than trying to take it away from stiff leafs...
Old 03-03-2009, 06:15 PM
S10xGN's Avatar
Gotta love a turbo!
406chevelle
Caltrac bars! I'm down to two leafs on my S-10, with P275DR Nitto's it gives 1.70 60ft times on street pavement (with a G-Tech Pro).
Rus
Old 03-08-2009, 11:30 AM
speedfreak2's Avatar
WrenchingAce
Hi bud. The leaf springs won't ADD traction per say. Their function is to hold the car up and provide a good ride. Traction bars are designed to aid traction. Now the Jegster bars are a great way to go and are very affordable. The cal tracs and the Competition Engineering Slide a links are IMO the best traction bars on the market today but at a substantially higher price. I have seen the Jegster bars in action (used to be the SSM bars) and they seem to work very well. I just bolted a pair on the '68 Camaro project I have and they were very easy to install and are solid.
As far as the leaf springs go...the five leaf will work great but the car will sit a little high. I prefer a four leaf spring personally. I installed a three leaf spring on a '68 Nova and they were a little too low. When you are ready to purchase the springs just let me know. I think I can get you a break on the price...maybe. AAA leaf spring is where I'd go when you're ready.
Old 03-08-2009, 08:01 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Check out the TV show "muscle car" they did a show awhile back about a sleeper nova with a stout motor. They made their own "super stock" springs by modifying a set of multi leaf springs. The thing hooked so hard it would overpower the traction of the front tires and push the front end around during a burnout.
Anyways, I think you can get traction and ride quality by modifying a set of stock springs.
http://www.truveo.com/MuscleCar-Fina.../id/2418580249
V8 Convertible Beetle Leaf Springs??? zbhover Suspension - Brakes - Steering 1 01-26-2009 09:44 PM
leaf springs 49dream Suspension - Brakes - Steering 2 01-12-2009 06:41 PM
Chopping coil springs Poison Heart Suspension - Brakes - Steering 37 10-19-2007 12:33 PM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
Valve Springs GearHead69 Engine 5 07-19-2003 11:00 AM
