Better lighting for blast cabinet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2005, 07:47 AM
cboy's Avatar
Last journal entry: Finished
I have a Harbor Freight blast cabinet and the light in it is almost useless. I mount a light over the viewing window whenever I blast now to help see a bit better but I need a better, more permanent solution. Anybody encountered this problem and solved it? (pics of your set up would be really nice.)
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 11-23-2005, 12:46 PM
I think a good replacement would be one of those flourescent tube drop lights. They are sealed well and the glass is encased in a polycarbonate tube. You could probably mount it with velcro or some means of zip ties. Might have to drill holes.
Old 11-26-2005, 06:50 PM
Hi Dewey,
I added a 100 watt light bulb with a "clip-on" alligator base to my blast cabinet (Cyclone plastic cheapie) through the right side door and I can see much better now. It came with only one on the left side.
Tom
Old 11-26-2005, 10:31 PM
I mounted a mayonaise jar lid to the inside of my cabinet then fastened
a light bulb socket to that. Drill a hole for wires,screw in a 100 watt bulb
then screw on the mayo jar. When the glass gets all frosted just get a new one!
Old 11-27-2005, 11:57 AM
cboy's Avatar
red911 - do you basically just have a bare bulb inside the blasting cabinet?
randywrench - great idea, sounds like it might be the ticket. Could even put in a couple of them.
Old 11-27-2005, 12:09 PM
Hi Cboy,
Yes, because the cabinet came with one on the left, so I put one on the right. I do like randywrench's idea however.
Good luck, Tom
Building your own sandblast cabinet Kevin45 Garage - Tools 17 05-07-2008 02:56 AM
Florescent lighting & Winnipeg weather CET Garage - Tools 9 02-11-2005 04:22 AM
blasting cabinet help HzSandman Garage - Tools 3 06-14-2004 10:56 AM
Shop lighting bigkid Garage - Tools 10 01-12-2004 08:35 AM
When have enviromentals laws gone to far -long articles- matty Hotrodders' Lounge 33 09-10-2002 03:20 PM
