Better suspension set up for Chevelle
Hi everyone,
I recently got plans for ladder bars from willys (thanks 1.When useing ladder bars is the anything else you should always use such as a panhard bar or a dia. link? 2. Stock length of the lower control arms is 22 inches bolt to bolt. I somehow believe this should be longer for ladder bar use ( since it is a rather big car) and also set lower so the bars are at less of an angle. Can anyone tell me if it would be right to make longer bars. (More fab. will have to be done to do this but if it is the right then to do then im all for it) 3. I see some ladder bar set ups mount in front of the axle and others that mount below it. What is the reason for this? For a car like mine what would be the best place to have them mounting both front and back? If someone could just explain this to me a little better. I want a good working suspension for the street and track. I know there is so much to learn about this and I have read through about 50 posts which has helped but I still would like some direct input on this. Thanks everyone! Chris |
Hey Chris,
This is a real good read: http://www.cachassisworks.com/TechTi...ip-001_WEB.pdf It should give you some insight right from the supplier. I won't recommend ladder bars for a street car. There are plenty of guys on the site who will vouche for them though so continuing asking questions until you are satisfied. Mark |
thanks Mark,
That is a really great link. It explains different things I had asked about very well. I think that making the bars is within my grasp and I can do that. I also have worked up a design to correctly mount the bars to the car. It will requires a new cross member but I can then have brackets that come off that to allow for the most adjust-ability. Making the bars and such is not so much the hard part but I want to have the placement correct before I start making. I have a pretty good idea how to make everything just where to measure first and the final placement that I need to understand better. Chris Last edited by strikingthematch; 03-18-2005 at 02:03 PM. |
From my understanding the only real reason not to use them is that they can cause binding. On even ground they work great put when one tire say hits a pot hole it can cause one side to bind and bend the bars or break something. To get around this you use poly or rubber bushing in the end of the bars (where it attaches to frame) The bushing allow for the bars to give a little and allow for movement of the frame. Kinda like your stock lower conrtol arms do. In most cases this sloves the problem as long as your not doing anything too extreme.
Chris |
| Using Wheel Scales To Set Preload | BillyShope | Suspension - Brakes - Steering | 8 | 04-20-2004 06:35 AM |
| Suspension Questions/Labor Prices | blitzkrieg | Suspension - Brakes - Steering | 4 | 06-30-2003 06:54 PM |
| Mustang ii Suspension | 41fordcoupe | Suspension - Brakes - Steering | 14 | 06-11-2003 08:12 PM |
| T-bucket front suspension | maddog200485 | Suspension - Brakes - Steering | 5 | 04-14-2003 09:20 PM |
| C5 Vette suspension into a fox body Mustang | Beau | Suspension - Brakes - Steering | 2 | 02-13-2003 07:39 PM |
