Better then JB weld! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-24-2009, 07:26 PM
Last journal entry: More painting pics
Originally Posted by Eric63M
Its true we do use this on military vehicles. ...........Eric
Thanks for confirming that for me Eric. I have always wondered it that was true! The 'super metal' kit we bought was fairly expensive but saved us about $5000 on a new prop and about 2 weeks of down time which would of been many more $thousands.
Many thanks to you and everyone else out there.
  #17 (permalink)
Old 07-24-2009, 09:21 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Originally Posted by OneMoreTime
would certainly solve an issue for me as I have a 250 chev 6 head to 12 port and filling the gaps on the 6 port head had me puzzled..
Sam
I did exactly that on my 230 inline 6 head! I cast up '180 deg', isolated runner aluminum 4-bbl manifold and used Devcon plastic steel to isolate the siameze ports in the head. I built dams on one side using modelling clay, cut a mesh of window screen as internal support inside the plastic and poured the plastic steel and let it set up. A little grinding w/ a burr blended the ports to perfection. I brazed a rod to the bolt bosses inside the runners to complete the isolation. I used a Holey 390cfm 4-bbl carb. Made equal length 34" primary dual headers. This combo was great, car would climb a rope w/ bottom end torque, great gas mileage, plenty of top end too. See photos of the project in my Journal.
  #18 (permalink)
Old 08-10-2009, 04:37 PM
PapaG's Avatar
Ask me, Cause I don't know
Last journal entry: Kid Dean Car
Devcon is what we used to fill up the engine blocks when we were not going to run a water cooling system. The packing has changed so I can not tell which one we used. Good stuff to use in working on heads.
  #19 (permalink)
Old 08-11-2009, 08:27 AM
Wiki Edits: 21
As I say I like it too but it sure is $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$!! Can't imagine what it would cost to fill a block w/ nowadays.
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 09:48 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
