Better truck engine for Buick - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 02:18 PM
Mutt's37Buick's Avatar
I'm buying a 73 to 87 Chevy 1/2 ton pickup as a donor car for my '37 Buick Roadmaster.
1) Does anyone know if I'm better off with the '73-'86 5.7 or the '87 5.7 w TBI.
2) Does anyone know what the (actual) stock horsepower should be for each?
Thanks
Old 01-25-2012, 03:02 PM
techinspector1's Avatar
Wiki Edits: 326
In this case, I think I'd be lookin' for an LS donor.
Old 01-25-2012, 05:13 PM
A Vette engine is definitely on my radar.
I just need the truck front steering components and thought I might be able to find used truck that has a decent engine and transmission.
Thanks
Old 01-25-2012, 06:02 PM
Thanks
SMOG era 350 small blocks are not noted for power the range seems to be about 180 to 210. If you're planning on using the automatic tranny the 87-92 TBI engine with the fully fixed 700R4 is the way to go. The block will not have a roller cam but probably has the provisions cast and machined, so you can update the cam at minimal expense and hassle. It will have the single piece rear main seal which is a quantum improvement toward keep oil in the engine and off the garage floor.
Frankly the 37 would be beyond cool with a Nail Head but that's a totally different direction, but I think worth considering.
Bogie
Old 01-25-2012, 06:17 PM
Thanks for this info.
1) Does anyone know what changing a cam cam produce in HP in an '87-'92 350.
2) If I change it to an aftermarket carburator, can I get more HP?
Thanks
430-4 Buick engine Dtb1 Engine 1 08-21-2011 08:41 PM
75 buick 455 in a chevy truck??? deuce&a1/4 Engine 41 12-20-2009 11:40 AM
Buick in a Chevy truck Sonny's 75 Engine 0 08-31-2004 01:16 PM
350 buick in chevy truck? jrm123180 Engine 7 04-04-2004 12:03 AM
455 buick in a chevy truck mounts rifraf General Rodding Tech 11 01-25-2004 08:44 PM
