Beware of one piece oil pan gasket for a Ford 460..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2006, 06:00 PM
onebadmerc's Avatar
I need a bucket of arc sparks
I bought a Ford Motorsport one piece oil pan gasket for my 77 Ford 460 engine that is going into my 78 F250. The problem with this gasket is the two front and two back bolt holes are not large enough in the rubber coated steel insert.I though maybe I can ream it out with a drill bit just a tad bigger, wrong solution. The drill ended up snagging the steel when it was about ready to go through the other side. It then twisted the rubber around the bit tearing the gasket in half, while mangling the rest of the gasket. This kind of stinks since the gasket was $25. If you buy a one piece oil gasket and the holes are not large enough, send it back, don't do what I did and try to drill the holes larger.
1982 2.8L camaro berlinetta oil pan gasket 1961_MGA Engine 3 08-17-2006 03:25 PM
New pan gasket without raising engine? rapsag Engine 14 04-21-2006 02:49 PM
what oil pan gasket do i need? :( KNanthrup Engine 3 05-01-2005 07:25 PM
Oil Pan Gasket Chevy21 Engine 5 03-02-2005 09:15 PM
Front sump ford oil pan FAIRLANE DUDE Engine 5 02-19-2003 07:16 AM
