Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - beyond frustration
  #24 (permalink)
Old 06-02-2013, 06:21 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
If you have bare metal spots it's always a good idea to use some type of rust deterrent product like an Epoxy primer or even an aerosol etch before you apply color...just for that added protection and insurance, no matter how small the burn through.
The smaller parts will also give you a good indication of your gun set up to eliminate the orange peel. If your mixing your paint 4:1:1 with the proper temperature dependent reducer/hardner, your gun is set up properly as to pattern and air pressure and your painting at the proper distance, the orange peel problem should be eliminated.
