Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - beyond frustration
  #30 (permalink)
Old 06-03-2013, 07:52 AM
BarryK's Avatar
BarryK BarryK is offline
Originally Posted by benchracer1 View Post
hopefully by friday Ill be back in town and painting. I greatly appreciate your offer and will take you up on it. I used an old devilbiss siphon gun for years with no problems. I figured it was time to upgrade to hvlp and I am certain that once I am past the learning curve i will be just fine....Steve
Changing from HP to HVLP or RP and LV is one of the hardest things to do, a lot of little stupid changes too make the paint lay perfect that did not matter with the HP type guns. Nine out of ten times when a guy like you calls with the same problem, just upping the pressure at that wall corrects everything, where with the old guns, it did not matter one bit what that pressure was.
Once you get it down, you will never go back and you are going from a 25% to a 65-75 efficiency rating, so you will use less material.
The Following User Says Thank You to BarryK For This Useful Post:
Dirt bag 1 (07-13-2013)
