I think you would be happier with a Q-jet or Holley. Check some of the old posts.
The quality issues are over! Sheesh! Change the record already, Dawg.
Really simple to choose a BG carb. They have a chart that is based on your cam's duration. Look it up on your cam card and choose the cam accordingly. The most sure fire idiotproof way to do it is, CALL BG CARBS AND TALK TO THE TECHS. They are extremely helpful. I love my Demon carb. Took a while to get it sorted out but you'd swear the engine was fuel injected. HOWEVER, after saying all of that, if I had to do it over again I would go with a Qjet. Just can't beat the fuel mileage you get with those.
thanx for the reply's guys. I think if i do go with the BG ill have to go with a reman carb. atleast i know its been gone through and bugs fixed. seems to be a lotta love for the rochester, im curious if the rochester would have more bottome end torque compared to the bg carb.
There is a guy that goes by "Shaker455" over on the PY Forums. He's magic with carbs, and custom builds carbs for your specific combo. Extremely good results. Let me know if you're interested. His references and bonafides are impeccable.
well i went out and bought the 625 road demon jr. after i got it home i took a good look at it and noticed the rubber oring seals for the tranfer tube were poking out the ends of the tube. i wasnt going to take any chances so i returned it to the store, that was the only 625 they had so i picked up the 525 jr. it was much better. runs really well so far the only complaint is getting the throttle linkage hooked up, going to have to modify the bracket so it sits back a little farther so the holes in the linkage line up with the cable.
Soooooo......let me get this straight. You came on here and asked how to choose a BG carb. You were told about the cam chart. You also had a guy who works at BG suggest a carb and you wound up getting a carb that was NOT recommended by BG. Wow. I just don't get it anymore.
ya i know seems stupid but if you look at the specs on both carbs, theyre actually the same other than jetting. and the one has annular discharge instead of downleg. so if i need to i can just change the jets, no biggie right?
| BG Speed Demon Carb Jet Question | leejoy | Engine | 3 | 07-19-2007 01:00 PM |
| Tunnel ram carb selection | baddbob | Engine | 2 | 07-09-2007 08:05 AM |
| BG carb question | Carl 66 | Engine | 13 | 02-03-2006 12:43 PM |
| HELP cam, intake and carb selection? | sniper4570 | Engine | 5 | 01-15-2002 08:16 PM |
