bg fuel pressure regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2005, 01:40 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
i have a 1975 trans am with a 455 pontiac engine.i had a problem with it stalling out and hard restart.i found my plugs were fouled out.normally this doesnt happen.it runs very strong with a good color on the plugs.i put a new set of plugs in and ran it.I then noticed that it still chuggs pretty hard.I found that my fuel pressure is going to almost 20 psi and is now overflowing the caeb.my bg fuel pressure regulator has failed.If the bg guy is on line,can i get a rebuild kit for the regulator or is it just all done?
bill g.(one fast t/a)
Old 09-15-2005, 03:42 PM
Technical Support Barry Grant
They can be rebuilt. Depending on which model you have will vary if it can be rebuilt in the field, or if it would need to come back to the factory. Suprising the engine would even run with 20lbs of fuel pressure. Which model regulator is it?
Fuel Pressure Question jdhoggg Engine 13 06-10-2005 08:29 PM
1:1 Boost referenced fuel pressure regulator means?? 84Z Engine 1 11-09-2004 11:54 PM
Fuel pressure drops when electric fan turns on Palmtrees57 Engine 3 09-04-2004 01:12 PM
fuel pressure jtcamaro Engine 1 06-01-2004 12:29 AM
Fuel Pressure on Edlebrock Perfomer 600 trick66 Engine 1 03-22-2003 04:10 PM
