BG quality control, or normal? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-15-2008, 05:12 PM
Customer support for the tards
I second that....
  #17 (permalink)
Old 09-15-2008, 05:18 PM
Originally Posted by rsk289
Am I going nuts?
I just received two packs of straight squirter jets from Jegs for my Mighty Demon. I want to try dropping a size, so got some 28s (two packs because I wasn't sure if they were sold singly or in pairs).
Opened them - and they're all blank! Both pairs undrilled, and no sizes stamped on them. Why label the packaging with a jet size if they're blanks? Is this normal, or is it good 'ol BG quality control again? Two different packs?
Huh!
Think of the gas mileage you'll get, LOL.
Bogie
  #18 (permalink)
Old 09-15-2008, 07:09 PM
Guy Hiltz's Avatar
Originally Posted by Ibaplayer
I second that....
Make that 3 X for me !!
Tech @ BG has helped me out a couple of times.The BG carb he recommended has been one of the best investments I have made for my engine.His advice & help is greatly appreciated.As he said,do you see anybody from Holley,or any one else, on here offering their help ?? I had absolutely no QC issues with my carb,and if I ever need a carb in the future,it will be from BG.
Guy
  #19 (permalink)
Old 09-15-2008, 10:34 PM
DoubleVision's Avatar
Some years ago I purchased a road demon Jr. from Summit. After some issues (such as CNC machining trash in the circuits) it served me well.
One thing I quickly learned about demon carbs. They aren`t so simple as bolt on and go as many carbs say. You have to read the book that comes with them and learn how to tune them correctly to your application.
Many carbs are forgiving to tuning errors and the demon carb is not.
The only thing I disliked about the carb was down leg boosters on the primary which made it a little on the lazy side. It had annular boosters on the secondary side and when I kicked it in the power it made was incredible, it felt like the car had been kicked in the rear with a giant foot.
Now days I only run Q-jets, but if I was to buy another carb it would be a Demon. I stopped using Holley`s after dealing with very poor quality control. I used to have a 600 holley and after possibly 10 WOT runs, the secondary bushings were completely worn out, I found they were 2 cent plastic pieces and nobody at the time including Holley carried a replacement for. Other times I bolted on new Holley`s on others rides to find no gaskets on the bowls or O gaskets on the bowls bolts. So its true, all companies have quality issues. But what I said is especially true, any company that says a carb is "bolt on and go" is pure BS. You have to tune the carb to the application regardless, cause every engine is different.
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
BG Blower Jetting and Pump Cam 68NovaSS Engine 2 07-10-2006 08:42 AM
Traction Control jmcrosby Suspension - Brakes - Steering 2 04-08-2004 07:39 AM
Help - quality of TRW suspension parts 69Z Suspension - Brakes - Steering 8 01-08-2004 07:28 PM
Quality Control????????? dmorris1200 Hotrodders' Lounge 11 10-15-2002 08:32 PM
