BG Speed Demon Choke problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 08:28 AM
malc's Avatar
Living At The Speed Of Life
I installed my carb and did not notice that the gasket on the choke side needed to be trimmed to the carb baseplate shape. This resulted in the choke mechanism not being able to function properly.
I noticed the mistake but after cutting the gasket back the choke still failed to operate, the plate closed but the high idle did not work.
I dismantled the whole issue right down to removing the parts off the throttle shaft.
This was fun, as the outer part left the scene and now resides in the front crossmember, to be picked out later. I had a new choke kit on hand so I could continue.
I found out the throttle shaft is very slack and can be moved up and down with fingers and fuel is leaking from there.
Not being able to do more I reassembled the choke, but the parts on the end of the throttle shaft needed to have a washer placed between them and the carb, see attachment.
The whole setup was very slack and caused the choke not to initiate high idle as the two parts did not engage.
I would like to ask tech@BG if he thinks this fix is good and to point out the instructions for installing the choke, especially the two pieces and spring on the shaft are not very clear.
I´m not climbing on the BG bashing train just pointing out a picky problem.
Old 02-01-2006, 01:48 PM
i've had a similar issue with my choke on my demon the fast idle was not working after trying differnt things and getting fed up i just sent it back to BG. and they fixed it up for me they said choke was not functioning properly and the pump arm was rubbing the endplate. seems to be fine now.
Old 02-02-2006, 07:40 AM
Technical Support Barry Grant
Choke Problem
Malc,
The metal bracket that holds the fast idle speed screw is thin, and can bend if caught up on the gasket. Installing the washer as you have will prevent it from bending, so you should be good to go.
speed demon problems gr8z28 Engine 27 11-09-2005 07:24 PM
More BG Speed Demon questions Jacks77 Engine 21 08-18-2005 04:58 PM
Barry Grant 750 Speed Demon hestitation Jacks77 Engine 13 08-16-2005 08:09 AM
Speed Demon 850 Rhansen Engine 2 08-14-2005 10:56 AM
Saganaw 4 speed with speedo problem JRinTX Transmission - Rearend 1 07-12-2003 06:23 PM
