Bias ply tire shake but sometimes smooth as can be - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 06:59 AM
cyclopsblown34's Avatar
Colorsanding painter
I have a 93 Toyota peekup with Super Swamper Thornturd tires 35-14.50x15 on 12" wide Weld wheels. One tire has a problem, sometimes it'll run down the highway as smooth as can be and others it'll shake bad enough to make me slow down. I can watch it in the mirror and when it is shaking, I can actually see the tires appear to be moving in and out like the tread is squirming. I've moved it to the front and the shake moves with it. Fastest I run the thing is 60MPH but this is frustrating over a 20 mile drive one way to work. I keep the tires at 20 PSI I've run them up to 30PSI and as low as 10 PSI and this is the only one that has the problem. The tires are about four years old and I've never reversed rotation on them, I rotated them front to back and that's it. I remember an old wive's tale about do not make a bias ply turn backwards to what it has alwys run. Any ideas?
Thanks,
Chip.
Old 06-17-2010, 07:22 AM
sqzbox's Avatar
My pipes are my music
Take your tire in question to a local tire shop and have the balance checked.
While it's on the balancer (spin type) have the tire teck check for belt separation, out of round, uneven wear, or bent rim. You might have just lost one or two of those stick on wheel weights. Another thing, water might have got in the tire from an air tank that wasn't drained daily like it should be. I've had tires with gobs of water in them. I always check the air hose with my finger nail just to make sure it's not full of water before i air up just to be sure. Bad places are convenience stores with slackers who don't do their job and drain the tanks daily.
Old 06-17-2010, 10:23 AM
Wiki Edits: 31
60 is about all those trucks can handle with anything bigger than stock tires.. great trucks offroad but over the road, there no good. as far as the shake. it sounds like a belt seperation
Old 06-17-2010, 10:27 AM
I was thinking a separation would be a constant problem. I guess the shake can come and go with a separation.
Old 06-17-2010, 03:44 PM
The bias-ply tires we've run before would develop flat spots, when parked for X-amount of time. When we start driving, there'd be a "clopping" and you'd feel the flat spots as well. Eventually they'd smooth out. But since only one of your tires is giving you problems, you should take it back in.
Old 06-17-2010, 08:43 PM
T-Bucket, Corvette, Mustang
I had the same problem with a set of bias plys on my T-Bucket. Tires about the same size on 12" wide Weld draglite wheels. One day would be smooth, next day they were horrible at anything above 45 mph. They would smooth out somewhat after about 15 minutes - those flat spots mentioned earlier. Had them balanced half a dozen times, using static and dynamic techniques - all no good after a couple days. When they were not smooth, you'd swear they felt like you were riding in an old Huey.
I then tried a set of 16.5" wide Hoosier pro-Street radials. Definitely better, but still not good at highway speeds.
Then went to a narrower radial with a lesser sidewall load rating on an 8" wide draglite. Now that fixed it all. It appears that the car just wasn't heavy enough on the rear axle to 'make' the tire roll smoothly on the large tires. I believe the centrifugal force of the rotating tire caused it to eventually get slightly out of round (perhaps after hitting a bump) when you got it up to a certain speed - think of an old time pizza maker slinging around the pizza dough over his head. The stiffer sidewalls of the larger tires didn't flex enough with the lightly loaded axle. You had to run about 5 lbs of pressure to get the flex on the larger tires but that was no good for general cruising especially at highway speeds.
Don't know how this helps the OP at all, but that was my experience with bias plys.
Old 06-17-2010, 11:00 PM
sqzbox's Avatar
Love them old huey's! Saved my butt a few times! bumpy or not.
Old 06-20-2010, 05:26 PM
I actually just read a magazine article about this the other day and it seems with bias ply tires that they do not keep there shape and balancing wont cure the problem. What they did was actually spin the tire mounted on the vechile and cut the face of the tread with a machine just to take enough off to make them round again.
Old 06-23-2010, 08:50 AM
Thanks for all teh replies everybody. Looks like the truck has a set of radials in its future unless someone else falls in love with it.
Old 06-24-2010, 01:42 PM
sbchevfreak's Avatar
Licenced Automotive Technician
You can shift rotation on a bias ply tire, but not on a radial. Once a radial tire takes a "set", it is permanant. I wouldn't recommend a bias ply on any street driven vehicle if radials are availiable, unless it is a resto job.
Old 08-29-2011, 07:31 PM
Balancing super swamper info
Here is some info on balancing super swamper tires
http://www.tirebalancingbeads.com/ho...terrain-tires/
Canadian Tire wrecks engine 4 Jaw Chuck Hotrodders' Lounge 31 12-09-2010 10:39 PM
I Think Someone Doesn't Like Me. (3rd tire problem) Ghetto Jet Hotrodders' Lounge 12 05-22-2009 05:15 AM
Old Guy Question: Vintage 4 ply tire pressure lakeroadster Suspension - Brakes - Steering 6 07-08-2006 01:58 PM
Rear tires on a T-Bucket cucumber1949 Hotrodding Basics 7 08-05-2005 03:32 PM
pro-trac (cold tire bounce) rhcrazybob General Rodding Tech 8 03-04-2003 12:51 PM
