Big 3" exhaust on '71 Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2003, 01:21 PM
New Member
Post Big 3" exhaust on '71 Chevelle
I've purchased the 'x-pipe' and flowmasters, (both 3"), and would like to run 3" tailpipes out the rear. This system will be hooked up to a 502/502. Will 3" tailpipes work any better than 2.5" (or is it worth it), and is there someone out there who sells big tailpipes for chevelles? No luck with Summit, jegs, Scoggins, and some of the other restoration vendors. They only have 3" pipes to the mufflers, not tailpipes. Thanks for the advice!!
Old 01-21-2003, 01:49 PM
4 Jaw Chuck's Avatar
Post
Not much to be gained going to a 3" pipe, except for the sound, run 3" to the muffler and then 2.5 out the back. Besides ever try to get 3" tubing bent?
— Han Solo
Old 01-21-2003, 01:54 PM
F-1Rodder's Avatar
Post
It will be loud.
Old 01-21-2003, 02:16 PM
dmorris1200's Avatar
doesn't play well with others
Post
What I did with mine was had my local Meineke (exhaust shop nearby does a lot of custom work) run 2 1/2 inch around the rear and then bumped it up to 3 inches out the back. Looking at the car on the ground you only see the 3 inch out the back. The pictures are large (500K) so I posted two links to the pictures instead of displaying them here if you want to see. One pic shows how it's run under the car and the other how it looks on the ground.
<a href="http://hotrodders.com/cgibin/album/album.pl?photo=00001452/IMAG0004.JPG" target="_blank">underneath car</a>
<a href="http://hotrodders.com/cgibin/album/album.pl?photo=00001452/Mustang5.jpg" target="_blank">car sitting in driveway</a>
BUILT FORD TOUGH
Old 01-21-2003, 02:20 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Any good muffler shop should be able to bend the pipe for you. I have 3" all the way on my Vette.
Welded all in 1 piece and easy to drop to work on.
Luv the smell of NITRO in the morning.
Old 01-21-2003, 05:38 PM
Post
You can get away with a lot more in a Corvette than in most cars because of their suspension. Just look at how low most of them sit to the ground, it's amazing they don't bottom out evey ten minutes. It's one of the things I always liked about Vettes, just looks cool sittin' down low.
BUILT FORD TOUGH
Old 01-22-2003, 07:33 AM
1BAD80's Avatar
Wiki Edits: 2
Post
A friend of mine bought a set of Stainless Steel pipes pre-bent for his Camero that are 3" and fit great with Flowmasters. Loud but nice.
Old 01-22-2003, 09:20 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
For a 502, I would say yes to it working better. I have 3 inch on my SBC400 with flowmasters. It sounds great, and I had no problem getting it bent.
Chris
