Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big air compressor info...
Old 02-16-2011, 09:42 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Compressor pump will only run one direction. Look at the large pulley on pump. The legs form a fan and must direct air over the pump while running.
The odd looking tube has a valve in the compressor end that equalizes the head pressure when pump stops. This keeps the pump from trying to start against full tank pressure.
