Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big air compressor info...
Old 02-16-2011, 09:40 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by BOBCRMAN@aol.com
The odd looking tube has a valve in the compressor end that equalizes the head pressure when pump stops. This keeps the pump from trying to start against full tank pressure.
Yes... your right about the little line bleeding off the head pressure, But they are not usually tied in at the crank case..
