Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big air compressor info...
Old 02-17-2011, 05:49 AM
cal1320's Avatar
cal1320 cal1320 is offline
Pulley on compressor should blow air towards the compressor jugs to provide cooling. To reverse rotation on 3 phase you need to swap any 2 of the 3 hot leads that feed the motor. This can be done at the disconnect or breaker box. Please make sure you have turned off the power and check for voltage with a tester before you work on electricity.
