Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big air compressor info...
Old 02-17-2011, 05:21 PM
oldred oldred is offline
If you only ran it less than a minute then you can forget about it even happening., I can guarantee it didn't hurt anything. As for that line you need to examine the pump head and see if there is anything that has been plugged off, it might explain where that line goes. More likely it was plumbed into the discharge circuit somewhere between the back-flow valve in the tank and the pump. Can you get a better picture of that line/tank connection? I know you have a clear close up but the fitting is partially obscured at the top by that braided line.
