Big air compressor info... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-23-2011, 09:55 AM
ogre's Avatar
the 'Duracell Project'
that is one heck of a compressor. your lucky to have 3 phase in your shop.
with all the shops around here going under, used 3 phase stuff is cheap now.
that tube may be an clutch type unloader.
some of those bigger units were set up to run the motor continuous
and clutch the compressor in and out.
this avoids a lot of restarts of the motor under high air use.
our shop has a 7 hp 2 stage that puts out 34 cfm @ 90 psi.
we can set it to run all the time by opening the intake valves using a regulator.
never have, we don't use that much air.
it looks like your compressor has 4 pistons; twin 2 stage compressor heads.
might be 50 cfm @ 90 psi. that's a whopper.
  #17 (permalink)
Old 02-23-2011, 06:16 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Your are right. The three phase stuff is going super cheap right now.
That is very interesting about running the motor all the time.. Just like a gas compressor.. I never thought about that. We really don't use that much air, but thats good to know.
  #18 (permalink)
Old 02-23-2011, 08:15 PM
Originally Posted by Silverback
That brass fitting in the top of the tank is a check valve, so air can only go into the tank, and the small line is an unloader that connects between the pump and the check valve so it doesn't have to start against the tank pressure. I'm actually surprised that it's necessary, I would expect that the volume between the pump and the check valve is small enough and the pump would leak enough that after a few seconds there wouldn't be significant pressure there...
Along these lines, I've always wondered if there is any way to tell which way the compressor should turn without a pulley on it? I have a big old Kelogg compressor head that I intend to setup at some point but I have no idea what direction it needs to turn.
What model Kellogg?
old compressor info needed pstrbrc Garage - Tools 5 01-29-2011 08:10 PM
Air Compressor Specs and General Info. TurboFord Garage - Tools 2 02-16-2006 08:45 AM
info on air compressor rs327camaro Garage - Tools 6 07-17-2005 10:39 PM
Paint gun and compressor info CdnSoldier Garage - Tools 1 04-16-2005 09:28 PM
Info choosing air compressor zonk Garage - Tools 1 01-23-2004 02:23 PM
