#1
The Big Block
Lets build a car with a big block and make it fast on the drag strip.
Register now (free) or login to remove ads |
#2
Then, let's!
Okay, try this out.
Start with a 1970 nova. Gut the living crap out of it and see how light you can make it. Cage it of course. Add you a-typical 454 with Merlin heads, H-beam rods, forged 4340 crank, 12.5 compression pistons, a good solid lifter cam from Comp, a dual four tunnel ram, and super t-10 tranny with a vertical gate shifter, ford 9" rear with 4:33 gears and a detroit locker. Add 110 octane fuel, and brace yourself for low to mid tens. I could go into detail, but that would take far too long. A very similar setup was used on a non-lightened '66 chevelle, and it made 11.06 on it's very first run with a single four barrel holley. |
#4
engine
13.5:1 632 with a set of AFD big cheif heads, DFI and 4 kits.
End of conversation... Now build it and let us know how many diapers you need to keep your shorts clean when you race it. Keith |
#5
Call Sonny Leonard and spec out the parts for an 932 cid engine w/streetable c.r., camshaft, wet oil pan and induction (k-star's DFI and 4 kits sounds about right).
In race tune it makes 2140 HP @ 8.1K rpm and 1475 ft/lb. torque @ 6.5K rpm. 932 ci w/5.080” bore x 5.750” stroke. In street trim, it should make fairly good power. Mortgage the house and go to work. To see his site, click here. |
| Thread Tools | Search this Thread |
| Similar Threads for: "The Big Block" | ||||
| big block or small block chevy | 69YENKONOVA | Engine | 81 | 05-13-2010 07:26 AM |
| Big block chevy into a 91 S-10?? | 12second6 | General Rodding Tech | 11 | 04-28-2009 06:43 PM |
| Big Block 82 Pontiac Gran Prix | william27103 | Engine | 3 | 03-30-2009 12:50 PM |
| Ford Big block 4 spd bellhousing | bigblocktorino | Transmission - Rearend | 3 | 10-05-2006 03:56 AM |
| Small Block Vs. Big Block | bfrett123 | Engine | 3 | 10-14-2004 05:27 PM |
