big block 454? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2008, 04:20 PM
RAT_FINK's Avatar
big block 454?
well i just traded a bunch of monte parts for a 454,so heres my question.what would the best way to make 1000+hp be?i was thinking roots blower or a turbo,but i can decide,can someone help me?i need a parts list.thank you in advance.
Old 12-07-2008, 04:22 PM
techinspector1's Avatar
Wiki Edits: 326
Old 12-07-2008, 04:35 PM
RAT_FINK's Avatar
whats that mean?
Old 12-07-2008, 06:27 PM
Wiki Edits: 326
By "traded for", I assume this is a stock production block and while I could be wrong, I don't think the main webbing in a production block is up to containing 1000hp.
The "eek" emoticon would be the look on your face as you realize you just ran over the rotating assembly with the rear tires.
Old 12-07-2008, 06:59 PM
Good luck trying to keep it from Regurgitating all over the track with a stock block. A gen 5 or 6 with good crank etc will start pulling the block apart at about 950 or so. You can build a reliable 750 HP 468 and not have any problems with the lower end but 1000 I would spend the 2500.00 it takes to buy a Dart block.
Old 12-07-2008, 07:00 PM
got $9k+ in your wallet for just a street HP blower motor????
here's a truly barebones/basic 454 blower motor build example:
http://willysreplacementparts.com/454.html
you do want forged crank/rods/pistons/stud girdle/etc so it will last which are not listed....
should use better heads than listed...
boring/honing wasn't listed
improved valve train not listed
basically, throw away every part except the block,,,figure around $10k as a budget for a street level HP blower motor
wanting to twin turbo a 454 big block cherry_camaro Engine 25 07-25-2009 03:26 PM
427 Big block blew up, need a few suggestions. esears Engine 17 03-12-2007 08:18 AM
Small Block Vs. Big Block bfrett123 Engine 3 10-14-2004 05:27 PM
Small Block - Big Block, what are they? Juicer Hotrodding Basics 49 09-01-2004 12:16 AM
69 Camaro Big Block Underhood Photos?? EricTopless68 Camaro Engine 4 03-10-2004 06:03 PM
