Big block 454 and small block match up - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 02:28 PM
boneyard Buick's Avatar
hey guys i got a chev pickup with a 454 in it. I want a smaller motor. I got a completely rebuilt 350 and my step dad says the 350 will just bolt right up in place of the 454.
Anybody have any experience with this? i just need to know, because 454's are soo thirsty.
Ryan350 :thumbup:
Old 01-27-2006, 02:36 PM
stepside454's Avatar
its a bolt in with the right brackets & mounts for a small block. & also exhaust manifolds
Old 01-27-2006, 03:05 PM
How thristy is it???
Old 01-27-2006, 03:37 PM
"its a bolt in" does that mean that the sbc 350 will bolt up to the existing transmission that i have in the truck? it's a 4 spd std. exhaust isnt an issue..got headers for the 350 etc..
someone told me that the 454 motor mounts are the exact same as a small block.. ?
Ryan350 :thumbup:
Old 01-27-2006, 03:40 PM
poncho62's Avatar
Wiki Edits: 5
You will have to get a different flywheel. The 454 is externally balanced and the 350 is internally balanced.
Dont be suprised if the small blocj is just as bad on gas as the big block......and, a lot less fun.
Old 01-27-2006, 03:57 PM
alright thanks guys...so flywheel is basically it?
Ryan350 :thumbup:
Old 01-27-2006, 07:06 PM
Bumpstick's Avatar
Hammer and a torch
Manifolds, brackets, water pump, pulleys, fan shroud, several other little trinkets and of course the flywheel as mentioned...
Also I like what Poncho62 said...
Dont be suprised if the small block is just as bad on gas as the big block......and, a lot less fun.
Old 01-27-2006, 07:11 PM
i got the 454 in a 4x4 truck, it was rebuilt in 99 and old man driven. I got a 350 thats done up with flat tops, 490 cam, ported heads, springs done, valve seals, valves, all balanced, edelbrock 600 on it air gap intake. I wanna do an overhaul on the 454, so i want somethin in place of it so i can still drive my truck.
Now... is there a length difference with the 454 and 350? would i be able to pull the 454 out and basically DROP the 350 in its place with a new flywheel. Thats my main question anything else is no big deal i just wanna know if the 350 will take the 454's place with a new flywheel for a little while
Ryan350 :thumbup:
Old 01-27-2006, 07:25 PM
Bumpstick's Avatar
Hammer and a torch
To answer yes... The distance from the bellhousing end to the mounts is the same from SBC to BBC... Just use the same "hood" type mounts...
Also here are some pic`s of my truck with the BBC in it...
And here are some of the same truck with the Vortec headed SBC in it... (about a year ago)
Internaly for the SBC... Also in the pic`s I used the exact same mounts and if you notice the exact same brackets and serpentine system with pulleys too... (not real hard to do just some thinking...)
Old 01-27-2006, 07:27 PM
alrighty all i needed to know. and i need an internally balanced flywheel or externally? thanks guys big help
Ryan350 :thumbup:
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Small block VS big, times a' changin? killerformula Engine 108 02-18-2006 12:16 AM
Big chev 454 and small chev 350 bolt pattern boneyard Buick Engine 4 01-18-2006 09:07 PM
big block in a car that had a small block bigpimp2988 Engine 4 11-20-2003 07:28 PM
swapping a small block for a big block Jim Vines Engine 3 09-14-2003 08:07 PM
