Big Block '71 Firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 12:31 PM
Hi name's LEW. This is 'Naydean' Just dropped in the Chevy 396. Having problems with bellhousing for 11" clutch/flywheel set up! what starter do I use for this? HelllPp!!
ID:	52658   Click image for larger version
ID:	52659   Click image for larger version
ID:	52660   Click image for larger version
Old 02-13-2011, 12:51 PM
I use a MSD geared reduction starter.It takes all the guess work out of starter problems.To use the 11 in. clutch disc you will need the large bell housing.
Old 02-13-2011, 03:35 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site. Got any actual pics of the car ?
Cole
small block to big block swap in a 91 camaro help! Greg O Sandsten Engine 6 11-02-2010 12:02 PM
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 07:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 05:37 PM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 08:33 AM
Pontiac Firebird & Transam engine block decoding TooMany2count General Rodding Tech 0 12-12-2003 11:27 PM
