hey guys this is a first for me please bare withme found a good deal on a 1969 427-435 how do you think it will do in a 1981 camaro this car been with me a long time just like to beef it up a little thanks
I"m afraid I"m going to have to disagree with instr396. 81 is a second gen camaro should be a breaze to do that swap. The easiest way is to get a complete big block with the brakets and power stearing pumps exc. It is true you will probably need a bigger rad and a good showd and you'll be laughing. There way also be a bit of interferance with the brake boaster and the valve covers if you are running tall ones but other wize it should be fine. The small block engine mounts will work too but you can get big block ones from lots of companies to. Besides this the only other thing that will need to be altered is the exhaust system. Oh and some times you might have to flip the heater core cause its pretty tight beside the valve cover all in all though its a pretty easy swap
Oh and as for the hoot clearance problem you will be fine as long as you run just a low rise intake and a drop base air cleaner |
You will have to upgrade the chassis for the extra weight.
This site has 4 wheel disc brake setups, springs for the front. I bought the performance plus system for my Vette from them and the quality is very good. Good luck, http://www.vettebrakes.com/
Luv the smell of NITRO in the morning. |
It will drop right in.It may not clear your stock hood depending on what air cleaner you have and what motor mounts you use.If you need cheap headers,you can use the hooker headers that fit the 70 thru 72 camaro bigblock,but you need to use pre 1973 GM motor mounts since the hooker headers will hit the stock later style clamshell mounts like you have on your Z.If you want to better your chances of getting the engine to fit under a stock hood,call a good resto supply house and see if they can supply you with the engine stands{the part of the motor mount that bolts to the frame} from a pre 73 factory bigblock camaro.
I agree that tall valve covers will hit the brake booster,but stock or low rise covers will fit,since the bigblock was only availabe in camaros with power brakes.The heater hose location may be an issue,but it may not sicne factory air walso worked in the 2nd gen camaros with bigblocks.Your Z may already have a larger then standard 3/8" fuel line and pickup,which should supply a stock bigblock,but if you have the wimpy base model 5/16" line you need to upgrade.The front springs will be marginal.If you want to know how it will sit,get one of your 200# buddies to sit on the hood,and see if looks right to you.Bigblock springs are available by requesting stock replacement for a 1970 model with a 396 engine and air conditioning,but these springs may need to be cut down.If you plan on running headers and the factory aluminum intake on your motor and you plan on ditching the factory air conditioning system,you might want to try the stock springs first since the weight of the bare bones bigblock wont be that much more then a factory iron intake and exhaust manifold smallblock with all the air conditiong and smog gear intact.It reasons to say that such a swap does not conform to any legal guidelines.Good luck. |
1981 Camaro 502 Ram Jet
hey everyone alright iam 19 my first car was this 1981 blood red camaro. It has been abused so thats why iam modifying the whole car and I just bought me a 1974 Type Lt/Z28 Rare non decal car. Its in all original shape the car only has 75000 miles on the stock 350 and its beitiful looks brand new except for the back seat has heat cracking but iam going to get that fixed but this 81. Is a totally different story i bought when i was 16 for 750 bucks i thought a couple thousand bucks in to the car have a decent looking ride. One problem after a month of having it the engine started to smoke. I also did reserch back to the first owners and the reason they got rid of it was it got stolen and wrecked. They tryed to repar it with old berrlinta fenders and stuff that they had from there other camaros. The car is a z28 just a berrrinta clone which sucks. So iam going to be bringing it back. Then after about having it for a year some girl ran into me and ripped the front bumper so i gotta replace that now. Right now its the engine it runs rough for a 350 and smokes. So iam going to be ordering a 502 ram jet in a couple months ill have the money saved up. I know iam going to have to modify pretty much everything. Cut a hole in the hood for the ram jet to stick out. But i need to find some headers anybody know of any good headers that will fit on the car with the 502. Ive been serching and i cant seem to find any that looks like they would fit. After iam done with the engine iam saveing up for the interior which is all red inside except the dash . red out and in. I may change that to grey with black racing style stypes i saw a older car with that and it looked quite awsome. I dont know. The whole car needs whole off frame restoration actully but probably not going to happen. Well peace out bye mike
Hey well i did not relize it took me here i just registered but your engine should work just fine just up the suspenson and that sort of thing if not you might find flat tires well peace |
| Recent General Rodding Tech posts with photos |
