big block caddy fuel pump on fi motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2009, 11:43 AM
can u just bolt on a fuel pump on a 425 fuel injected motor
intake changed anything in the distributer to make carb work on this motor using stock parts?
Old 10-02-2009, 11:40 PM
Dogbreath077's Avatar
Old School Motorhead
Most Fuel injected motors do not have the fuel pump lobe on the camshaft. If you converted to a carb, then get a small add-on electric fuel pump.
Elec. fuel pump leaking into motor??? 0260N2.8 Hotrodding Basics 3 01-12-2009 03:06 PM
Electric fuel pump shut-off mur39 Electrical 22 03-05-2007 06:48 PM
windstar trans/motor problem bentwings Transmission - Rearend 26 09-13-2004 11:18 PM
Fuel Pump Too Big? 54 Chevy Engine 3 05-04-2004 10:54 PM
Set timing big block blower motor street rodder 1937 Engine 1 10-21-2003 09:57 AM
