Big Block Camaro Fan ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2008, 04:05 PM
Need to tap into someone's expertise.I have a 1968 Camaro Big Block I am in the process of restoring.I removed a 7-blade fan/clutch.Looking on EBAY I came across an original BB fan.It is a 4-blade.Not sure what is original or what whould cool better.Also saw a 4-blade w/spacer,stated original.
Should I stay w/7-blade and clutch or 4-blade w/spacer or 4-blade w/clutch?
Old 05-29-2008, 04:12 PM
techinspector1's Avatar
Wiki Edits: 326
That's interesting. I wonder why GM would have used less blades in that application? My first impression would be that the pitch is different. If you lay a fan blade flat down and measure from the surface it's laying on up to the edge of the blade, that's the pitch figure. I've always used an OEM steel fan of one sort or another through the years and have found pitches from 1 1/2" to 2 3/4" (Olds diesel).
Old 05-29-2008, 06:25 PM
Wiki Edits: 31
with 4 blades, it will likely have more pitch than a 7 blade fan, and it will make more noise. a 7 blade fan could use less pitch to move the same CFM of air with less noise, theoreticly less drag on the engine also but that amount would be negligable.
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
big inch small block Streetnova Engine 7 01-11-2007 08:12 PM
small block vs big block JUSTINH Engine 28 02-17-2003 04:37 PM
