Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big block chev/ 4-speed transmissions
Old 02-16-2010, 09:55 AM
bentwings's Avatar
bentwings bentwings is offline
bentwings
The only real concern is that you get a clutch disc that matches the spline on the trans. Not a real problem as everybody make them. Make sure you put in a new pilot bearing.
Stay away from the Saginaw as you will kill it very spectacularly with a good 454.
