Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Big block chev/ 4-speed transmissions
Old 02-16-2010, 06:06 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by big gear head
I forgot about that. You can get an after market front bearing retainer for the Muncie that fits the truck bellhousing.
That's exactly what I had to do with the Saginaw I'm using in the Deuce. It was from a truck and the front bearing retainer was too large to fit in a "car" bellhousing. A quick call to a Saginaw supply house in Vegas netted me a smaller retainer, a couple gaskets and a new tail shaft seal and I was good to go.
The Saginaw 4 speed was used in everything from Vegas to half ton trucks. Including small block Camaros, Vettes, and Novas and just about any low to mid performance GM model cars and trucks from the mid 60's through the mid 80's. The Muncie was used in all high horsepower applications simply because it was strong enough to handle a big block. My 66 Vette had a Muncie behind its 425 hp 427.
