big block chev hp rotating assy clearances - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 11:11 PM
I'm building a 400 pontiac motor with a scat crank which suit 6.800" big block chev rods . Could anybody help me with clearances on the big ends and the rod to crank side clearance .
Old 03-06-2012, 05:40 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
I'd call/e mail scat..
Old 03-06-2012, 10:06 AM
As far as rod bearing oil clearance, not much different than the Pontiac rods. Depending on use, I like to see .0015" min to about .003" for serious max but sometimes there's not lots you can do, reasonably. I've put them together with as little as .001" on fresh machinework(round) and as much as .004" when used eggshaped rods were used and they all worked. For rod side clearance, I like to see .010 min to .020". Once again, you can carefully make it larger if it's too tight but you can't make it smaller. I've seen them run fine with .040" or more. By the way, the old tale about using oil if the side clearance is big is just wrong. Don't worry about that.
Old 03-07-2012, 03:56 AM
stich626's Avatar
gearheadslife
you've reused eggshaped pontiac CAST rods. as is.?
really..
Old 03-07-2012, 04:48 AM
Big block rod clearance .
Thanks for your help guys , much apreciated
Old 03-07-2012, 07:34 AM
68NovaSS's Avatar
Wiki Edits: 9
Originally Posted by speedbump
...(Side clearance) I've seen them run fine with .040" or more. By the way, the old tale about using oil if the side clearance is big is just wrong. Don't worry about that.
I believe you're talking about a drop in oil pressure, not using oil, and is it something to be concerned about if you're building it right, but then if you reuse oval rods, why worry about it.
Old 03-07-2012, 08:17 AM
I didn't say it was correct, but it worked OK. Sometimes customers, budgets and just plain lack of knowledge can have you do things that aren't pristine. The point is they can work if they have to. Unless you have used new or Sunnen reconditioned rods in every build you do, you have used egg shaped rods. Might only be .001", but they aren't round. I spent a lot of money on a precision gauge for my Sunnen hone just to measure connecting rods. I was amazed at how used rods stretch, but then I didn't already know everything. I'll leave it to you to explain how, with .0015" to .0025" oil clearance which controls oil pressure, rod side clearance, no matter how much, is going to affect oil pressure....unless it's smaller than .0015".
LT1 rotating assy into a Vortec 5.7 block opinions Jim Rockford Hotrodding Basics 43 01-08-2013 09:07 PM
Eagle "ESP" Rotating Assy.. Smittydpd Engine 2 06-26-2009 05:11 AM
Master Cylinder Pedal Assy 53 Chev PU 53 5WNDO Suspension - Brakes - Steering 0 03-29-2007 12:03 PM
repair of door window assy and handle assy Carl Haughey Body - Exterior 1 08-25-2005 02:29 PM
rotating assy. balancing + mixing parts TerroRx7 Hotrodding Basics 4 04-03-2005 12:48 PM
