big block chevy casting 236 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 12:03 AM
i have found some heads with 236 castings are tjese good heads for a street head or should i stick with some 781 the 236 heads are 100 bucks
Old 04-24-2011, 12:13 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
236 heads are peanut port truck heads. Max out around 450 HP w/stock ports and valve size. 781 or 049 oval port heads have a lot more potential.
Old 04-24-2011, 06:59 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
X2.
i run a set of 049's and they work awesome for my mild built 454. would like some bigger valves, but in time i will get the work done.
Old 04-24-2011, 08:32 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
you cant beat those 781's (or 049's also)
from what i've learned, if you put big valves in them and dress up the porting, they are just about the perfect hot street bbc head.
236's would only be good on lower rpm motors without a ton of work.
i have a set of 236's that have low miles on a rebuild, i would just about give away.
Old 04-24-2011, 08:42 AM
Originally Posted by chevykid90
X2.
What size of valves do you have in them, chevykid90?
The 236 are good for low end grunt. But, upper end looses out.
Old 04-24-2011, 09:31 AM
well i am wanting somethen that sill get down and suck you na k in the seat the truck will never hit the track it is just a fun truck for around town.... the 781 heads came off a mud raceing truck so i think they have had a valve job and all
Old 04-24-2011, 11:18 AM
& matts38chev
bolt them on
Old 04-24-2011, 01:16 PM
chevykid90's Avatar
the stock valve size, 2.08 In 1.76? or is 1.77? Ex
i would really like to get them worked on and have the 2.19 In and 1.88 Ex. i shouldn't need valves bigger than that for what i do. i think any bigger and it would be a waste. and a better intake, mine chokes out after 5,500 RPM
Old 04-24-2011, 02:53 PM
I would check the 781's an make sure they are in good shape an ready to work with your cam. I think you will like them. I have a set of 049's with 2.19 an 1.88's in them. Will be bolting them on a block before long.
casting numbers small block chevy RWN Engine 1 01-05-2011 02:05 AM
chevy v8 big block casting numbers jason doyle General Rodding Tech 1 07-21-2007 01:04 AM
chevy small block casting numbers Chick Engine 2 03-15-2007 10:53 AM
chevy small block casting numbers Chick Introduce Yourself 1 03-15-2007 08:26 AM
350 Chevy block casting question flyin99 Engine 7 08-14-2006 09:55 PM
