Big Block Chevy combination question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2003, 05:35 PM
JamesRS's Avatar
Hi all, I have a question for the Big Block builders out there.
I just purchased a 72 Chevelle with a 454 that needs a rebuild. Car needs a "little" work. (read: the car is completely disassembled) I've built several small block Chevy's before, some for daily driving, some for street high performance, but never have I built a Big Block.
My question is this, what is a good high performance street (91 octane) combination that will survive in the heat of the desert, won't behave too badly on the street, but also will be able to lay down some good numbers when I take it to the track.
Any advice is appreciated.
(Turbo 400, 2000 Stall, 3.23 gears is the rest of the important stuff)
Old 12-15-2003, 06:46 PM
rifraf's Avatar
What heads do you have and how much do ya have to blow?
Old 12-15-2003, 07:53 PM
poncho62's Avatar
Wiki Edits: 5
Do a stock rebuild, RV cam, and thats it. You will be real happy with the results. Those are a great, torquey engine. Don't go too wild and you will be happy.
Old 12-15-2003, 08:45 PM
200mph's Avatar
what kind of hp and tq will that make?
Old 12-15-2003, 08:55 PM
odil1372's Avatar
poncho
I don't mean to confuse the issue, but I also have a Big Block that I'm building and I was wondering what you call an RV cam? About what size is considered for an RV?
Old 12-15-2003, 08:59 PM
200mph's Avatar
Need help making 454 put more hp
Ok,here's the deal, I have a 454 that put's out 425 hp and 500 lbs of tourq. Dose any one know how to make a 454 ut out more power?
Old 12-15-2003, 09:06 PM
What is your combo? Need details.
Old 12-15-2003, 09:12 PM
badknuckles's Avatar
you talkin to me?
425 isnt enough?
Old 12-16-2003, 04:54 AM
poncho62's Avatar
Wiki Edits: 5
In 72 a stock 454 was rated at about 300 hp. This was misleading due to the decreased compression ratio. It had a ton of torque, which you want more anyways. An RV cam is not just for RVs. Its is also called a mileage or towing cam, It is high lift, short duration, that gives better bottom end and torque right up to above 5000 rpm, excelent street cam.
The crane energizers are RV cams.
You said you wanted street performance at a decent price, thats why I say don't go overboard.
Throw a pile of money at it!!!
Old 12-16-2003, 08:31 AM
engineczar's Avatar
As simple as it sounds go to the Edelbrock site and look up the Performer RPM package for the 454. I built one for a customer a couple years back and he loves it. It's basically a .030 over 454 with the Edelbrock RPM heads, cam, and intake. We put a Holley 850 on it and a MSD7AL box and MSD distributor. His car is a 3400 pound 67' Chevelle, Turbo 400 w/ 3500 converter, 4.56 gears. The thing starts and idles like a champ and is very driveable. To top it off the thing turns 10.90's all day long with slicks and open headers. He has taken it to many street cruise nights all capped up with street tires and mufflers and says it's a blast.
Some people don't equate Edelbrock to making big power but I feel the combos they do have are pretty dependable and user friendly.
BSE Racing Engines
Old 12-16-2003, 02:21 PM
JamesRS's Avatar
Thanks for the advice guys, I was told the block has an RV cam in it, but I was leaning towards the Performer RPM package anyhow. Once I get the block apart, I'll know what shape the internals are in, and I'll know how much work is in front of me. After that I'll figure out where I want to go with it.
Thanks again.
Old 01-22-2011, 05:31 PM
ii also wantto rebuild a 454 for my c/k truck but i want a good rough idel to it but want it to be a pump gas toy
Old 01-22-2011, 06:02 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There are many ways, do a search here and on the net, HP cost money, how much do you want?
Old 01-22-2011, 07:08 PM
i wana make sonethen that will set you back in the seat and run on pump gas any sugestions
