Big Block Chevy Deck Height - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 10:57 PM
How do you measure deck height on a Chevy 454? Or, how does one know if they have a 10.200 deck or the 9.800 deck? Thanks!
Old 11-08-2010, 12:31 AM
DoubleVision's Avatar
You can do this by looking up the casting number, but on a whim where casting numbers aren`t avalible and your looking at the raw block most have the word "truck" casted into the block behind the timing cover. Another way to tell is look at the upper water pump bolt hole. The hole on the short deck block will be very close to the deck, less than a 1/4 inch. On a tall deck block the bolt hole will be about a 1/2 inch from the deck.
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 06:10 PM
4 bbl on big and small block Chevy Quick 58 Engine 1 11-21-2007 04:40 PM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
