big block chevy I.D. tag - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2013, 09:52 AM
ss396si's Avatar
trying to find info on my big block but havent had any luck.
The number as it appears on the pass front side of block is 7 C7FL52020
Old 04-10-2013, 12:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ID Chevy engines
Old 04-10-2013, 12:51 PM
RWENUTS's Avatar
Look for your casting number behind the drivers side head.
Old 04-10-2013, 02:21 PM
ss396si's Avatar
casting number #361959 454
Old 04-10-2013, 02:33 PM
RWENUTS's Avatar
Looked at your gallery!
Car looks good. A real sleeper look.
Are you lookin' to swap out the sb for a big block. No substitute for more cubic inches.
I had a couple chevelle SS's years ago. Both 70's. An LS6 and an L34.
Old 04-10-2013, 02:45 PM
ss396si's Avatar
thanks! I just picked up a BBC 454 w/ 781 heads from carb to pan. it needs valve seals and lash though. the crank turned and heads are clean! Hoping for the best on the bottom end, when i take the pan and head off, cross my fingers.
Chevy small block and big block bolt lengths zmaxmotorsports Hotrodding Basics 17 03-01-2013 06:55 PM
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 04:36 PM
Aftermarket Block Big Block Chevy camaro 68 Engine 2 09-15-2003 09:19 PM
55 chevy small block to big block ehchvac Engine 0 05-02-2002 09:23 PM
