Big Block Chevy into G-body - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2010, 08:21 PM
Hey guys, sorry I know this thread title has probably been used a million times before
but i have a question that I don't think has really been covered. but I'll give a little background first
1980 Pontiac Grand LeMans Safari Station Wagon G-body (very similar to the malibu wagon)
Put a Chevy 496 In it bolted to a turbo 400 trans.
Any way. motor is in, headers in, brake lines run ect ect...
My question is...Does anyone know if I can just get replacement radiator hoses for say maybe a 1980 Monte Carlo with a 305? I'm trying to find a set of hoses that will fit without breaking the bank and buying some custom do it yourself kit... I am an 18 year old kid in high school and this is my project car for the year.
Thank you to everyone for all your help.
Old 04-12-2010, 09:10 PM
ericnova72's Avatar
More for Less Racer
Best thing you can do is buy a piece of flexable exhaust tubing to use as a form, bend it to the shape you need and then head to your local autoparts store and start comparing the form to the rack of hoses. Another possibility would be to get the hoses for an earlier Monte Carlo or Malibu that came with a BBC and maybe trim them shorter.
Old 04-12-2010, 09:27 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you haven't been to maliburacing.com then you should check it out. There is a some good information for those cars available on and through that site.
Old 04-13-2010, 12:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you are either using the OEM radiator (if it had a Chevy V8) or an aftermarket radiator that has the same hose locations (top driver side, bottom passenger side), and a water neck that points in the same direction (angled between almost straight ahead to 45 towards the drivers side) the hoses for the '80 Malibu (I own one) w/a 305 will work. You will need to trim a couple inches from each end is all.
Another option is to use most any hose that has close to the correct bends as it leaves the radiator and the water pump, and use metal pipe between the bends. This works especially good on the top hose.
Flex hose will work for this, but doesn't flow as good as smooth hose.
8.1L 496 vortec big block chevy, what is it? 406 ss monte Engine 20 11-03-2014 11:11 AM
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 06:10 PM
4 bbl on big and small block Chevy Quick 58 Engine 1 11-21-2007 04:40 PM
