Big block chevy oil pans - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2012, 04:42 PM
I would like to hear some opinions on using a Moroso #20403 oil pan. This is to be used on a 1971 454 block with 496 Cid internals. I am also going to use recommended oil pump & pickup. Here is some of the info listed for it: Engine Application: Mark IV style (except Gen V and Gen VI)
Fits: Most chassis except 1962-67 Chevy II, V8 Vega/Monza and 1955-57 Chevy
Kicked-out sump and crank scraper
Uni-directional windage screen
Rear anti-climb baffle
Trap door baffling for improved oil control
Notched pan rails accept strokes up to 4.50" with most aluminum rods
Compatible with most starter/flywheel combinations
Old 05-29-2012, 04:51 PM
BOBCRMAN@aol.com's Avatar
You didn't say what body you intend to use.. You will find that a lot of these custom pans will not fit G-body cars.
Old 05-30-2012, 05:58 AM
Moroso oil pan
It's going in a 67 Camaro. I mainly want opinions on the internals of the oil pan such as windage screen, crank scraper, trap door baffling, etc. Has anyone used pans like this and had any problems such as oiling for piston skirts,etc.
Big Block Chevy oil problems miguelitosd Engine 16 10-30-2012 05:50 AM
prime an oil pump on big block chevy Chucky5150 Engine 17 06-06-2010 11:37 AM
80 Malibu Big Block Chevy oil pan ??? Ratoflic Engine 3 01-27-2010 05:59 PM
Oil Pump Bolt Big Block Chevy crazy8s Engine 3 09-09-2009 08:12 PM
Oil Pan Help Big Block Chevy 454 71 nova Engine 0 08-18-2008 09:51 AM
