Big Block Chevy oil problems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-30-2012, 05:20 AM
I've had this situation several times before on motors that sat up. In my cases the rings stuck. In all cases I bought a quart of Marvel Mystery Oil and dumped half in the tank and half in the oil. Run it till it warms up and shut it off and let it set for a couple days. Restart and the problem is gone. Even if thats not the problem in your case....all it cost you was about $6. This has saved me at least 4 times that I can recall.
  #17 (permalink)
Old 10-30-2012, 05:50 AM
67Mustang Al.'s Avatar
I agree with lilsmoke. To have that much crankcase compression to push the dipstick out i m o the rings are compressing on the downstroke far more than they should and a leakdown test would prove the ring seal against the cylinder wall as mentioned in an earlier post. There has to be something going on with the rings there.
i broke my 347 in on an engine bed for 30 minutes with 30w mineral oil +zinc for Hydraulic cam. The engine runs now on 10/30 +Zinc and has 1300miles on it with next to no oil consumption or crankcase compression.
Al
Big block Chevy starter problems 57 Chevy Pick up Engine 3 05-14-2010 07:27 PM
.060 block 350 any problems tomthecomic Engine 7 11-09-2008 02:12 PM
400 Small Block oil problems bac6772 Engine 40 07-05-2007 12:49 PM
fuse block problems mxpmxp Introduce Yourself 1 12-29-2004 08:16 AM
Big Block HEI problems!!! woodman13 Engine 4 12-20-2002 08:39 PM
