Big Block Chevy Overheating w/ Factory Serp Setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2011, 12:30 PM
Last journal entry: Some More Roll Cage Fabrication
I have an 86 chevy 454 with 93 serpentine belt setup in a 70 Nova. I have the water pump for a 93 setup(reverse rotation). I just completely rebuilt the engine(stock) and installed a comp solid 252 camshaft. The engine overheats during break in(10-15 minutes); never get to finish(tried twice). I also have a 3 core radiator(small block) with an electric fan(1150 cfm) with a 195 t-stat(stock for 86). The cap is rated at 16lbs. The car hasn't puked, I just shut it down at 230 degrees.
My question is: do I need the headgaskets from a reverse rotation engine? I rebuilt engine with a 70's kit. I noticed the head gaskets block the holes in the block towards the exhaust side(only steam holes). The gaskets for the newer engine style has the holes completely open.
I have tried mechanical(reverse rotation) mechanical fans of different sizes plus electric fans and redline water wetter.
I am confident it is not an air pocket; I put tylenol in t-stat holding it open and used a vacuum lift to fill cooling system.
I am going to try running a 160 thermostat and plumb in a crossover from head to head at the rear.
Any help is appreciated. Thanks!
Old 05-23-2011, 01:22 PM
Id say that raditor is too small for ur big block. Also right after a rebuild when the engine is at it tightest point it produces some extra heat. Try running a water hose threw ur raditor to keep it cool for break in or a big shop fan. Putting a 160 thermo in there wont do anything since temp isnt going low enough for it to close. You really need to run a mechical fan with a shroud. I run a electric in front of the raditor and a mech on the engine and i never see above 185 with a 180 thermo and thats in 100+ florida heat. Whats the core size of that radiator? And the crossover is a good idea but its only gonna help a little.
Old 05-23-2011, 01:31 PM
Also my radiator is a 3 row 23x17x 2 3/4. Most people i know use a 4row with a big block. And on a side note after u get the heating problem fixed dont run a 160 thermo, almost all engine damage is done during cold start up 160 is just to low. It doesnt let the thermo close long enough. Run the 180 and enjoy
Old 05-23-2011, 01:33 PM
It is the griffen(sp?) 3 core 17x21 aluminum. The core is slightly over 2.25 inches thick. I would think it could keep it cool. It kept my 355 w/ a 671 cool.
Anyways, I just ordered an aluminum factory replacement. It is 2 inches wider same core number, but I don't know how thick.
Mechanical flex fan made no difference(18 inches), but I don't have a shroud that will fit.
Old 05-23-2011, 01:49 PM
Shroud would make a difference. Are the pulleys underdriven? I did a custom shroud using sheet aluminum from home depot. I mocked it up with some carbboard first.
Old 05-23-2011, 02:07 PM
The radiator I ordered is only a 2 core aluminum, so I canceled it. I'm waiting for griffen to call me back on a better radiator. I usually run a 180 t-stat. I guess I will try a mechanical with a shroud.
Old 05-23-2011, 02:10 PM
The belt system is a stock setup.
Old 05-23-2011, 02:37 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Set the base timing to around 16*
And if you have a timing tape on the balancer---with vacuum advance----you will want to see nearly 45* or better at 2500 rpm
Bumping up the timing on my 454HO made a world of difference in the temps.
Also---make sure the water pump is working------had one engine where the impeller slipped off the shaft and was not pumping the water thru.
That was a head scratcher
Old 05-23-2011, 08:07 PM
My base timing is at 18*. The throttle response is excellent and the plugs are nice and Tan. I don't think it is a bad tune.
I have triple checked the water pump. My heater core hoses are hot and my upper and lower are hot. I didn't use my temp gun on them, I felt them with my hand. I even checked flow with the radiator cap off. I had previously suspected a non reverse rotation water pump was given to me by mistake so I actually disassembled the pump to check. It is correct and working properly.
I'm working on making a shroud for the flex fan. Griffen said 3-5 days for a new radiator. I will update when I have some more information. Thanks.
Old 05-24-2011, 11:32 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I run one mother of an aggresive flex-fan on my 66 with a 454, along with a
brand new (stock) 3-row 1966 Chevy truck rad, Spectra-Premium part number CU-284.
The original 6-cyl rad was only a 2-core, which was marginal during engine break-in even at a 50F ambient temp. It ran up to about 220 on the guage, but never boiled over.
Part Specifications
Core Material : Copper
Tank Material : Brass
Row No : 3
Core Height : 17-5/16''
Core Width : 25-1/4''
Core Depth : 1-7/8''
Inlet Header : 2-3/4'' x 25-1/4''
Outlet Header : 2-3/4'' x 25-1/4''
Inlet : 1-3/4''
Outlet : 1-3/4''
Eoc : None
Toc : 14-3/4'' (Concentric)
Notes : Installation Kit:
1 x Installation Sheet
When it runs around 2000 RPM, it moves a LOT of air, and will tug at my shop coat on the way by.
With this new rad (No shroud), and it runs at a consistent 195F ... matching the thermostat that I have installed. I may swap that out for a 180 one later.
Old 05-24-2011, 12:53 PM
I have a spectre 18 inch reverse rotation. I hope to get this shroud done soon. I will update when I have some information.
Old 05-24-2011, 03:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You definitely need to get it broken in, multiple tries is taking a huge chance with the cam. As mentioned before, a 160 thermostat won't keep water in the radiator to cool it and you absolutely need a shroud. IMHO you have enough radiator, and flex fans aren't the best setup around, a clutch fan will do you better.
Semper Fi
Old 05-25-2011, 09:46 AM
Success! Flex fan with a shroud and 160 T-stat. My car runs at a cool 160 degrees now. Thanks for the help. I finished the break in and took it for a test drive. I am now ready to tackle the a/c.
Thanks again for the help.
overheating small block chevy wildjeffpa Engine 25 03-04-2014 03:02 PM
Chevy 350 long block overheating jeff79 Engine 91 08-28-2009 03:45 PM
How Much HP Will a Factory Block Handle (SBC)??? camaroman7d Engine 8 01-14-2004 08:52 PM
Big Block Overheating stress76 Engine 2 09-30-2003 12:13 PM
Big block setup for my 57 Chevy kevink Engine 1 08-24-2003 07:42 PM
