Big block chevy problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2007, 01:42 AM
I am restoring a 70 chevelle with a 396. I pulled out the motor and transmission to both repaint the block and have the tranny rebuilt. I reinstalled them and attempted to fire the motor. It runs fine for about 5-10 seconds and then makes a really loud squeak sound (almost like a loose alternator belt), except the P/S pump and alternator are not connected yet. I have really good oil pressure and the motor ran flawlessly just before I pulled it. Any ideas?
Old 08-18-2007, 08:51 AM
Bumpstick's Avatar
Hammer and a torch
Does it continue to run...? Also is the water pump connected (noticed the alt & PS were not)...
I would make sure the starter is not hanging up first but could be a bearing...? Check the starter/flywheel first then it would be time to pull the distributor (check it also) and block up the engine and pull the pan... If its a bearing then the more you run it the worse it will get...
BTW was the engine rebuilt also...?
Old 08-18-2007, 10:02 AM
Jmark's Avatar
Sounds like the trans? Remove the 3 converter bolts and slide the converter back into the trans pump and re-start. If its now quiet, the trans is the problem.
Mark
Old 08-18-2007, 10:04 AM
The engine was not rebuilt. The water pump was not connected either. I rolled under the car and noticed that the starter gear was still enguaged with the flexplate. Could that make such a loud squeak? It's fine for the first 5 or 6 seconds. Then it makes that noise. I thought about the bearings as well, but since I never took the engine apart, the chances, I thought were low. Also, could it be my new transmission? That is the only piece that was touched. I just never heard a tranny make that noise before.
Old 08-18-2007, 10:08 AM
I'll disconnect the tranny and try it.....
Old 08-18-2007, 10:45 AM
Holder350's Avatar
Auto Parts Professional
I'd bet its your starter if it is not disengaging
Old 08-19-2007, 09:48 PM
It turned out to be the tranny. Thanks for your help, everyone.
8.1L 496 vortec big block chevy, what is it? 406 ss monte Engine 20 11-03-2014 12:11 PM
1996 Big Block Chevy Wiring Diagram Sick56 Electrical 2 01-02-2006 03:31 PM
400 chevy big block silentnight223 Introduce Yourself 1 10-07-2004 06:23 AM
Swapping to big block chevy low77ride Engine 5 09-15-2004 10:30 PM
Big Block Chevy NAIRB Engine 2 09-28-2002 07:49 PM
