When building your valve train from parts other than stock,you should use an adjustable checking pushrod to determine correct heights,valve clearances and rocker angles,then order the pushrods to the length you need.
Different combinations need different lengths. |
stock lengths are 8.280 and 9.250 but if your pieces have been machined its best to check with a set of adjustables as stated by prior post. its the only sure way.
The pushrods that were in the engine and failed were 8.5 and 9.5 inches. There is obvious wear marks on the rockers where the pushrods were hitting the body of the rockers when the valve opened fully. There was a side load on the rod that simply broke it off. Thanks |
Uh stock rocker ratio for a BBC is 1.7 and the only reason to not use a stock length pushrod (intake or exhaust) is because of changes in installed height of the valves so you can correct the geometry... (possibly a different base size cam also)
Also with the chewed up end of the pushrod what comes to mind are these stock pushrods...? (ball type end...?) also what size diameter are they...? |
The last BBC I owned was in 1973 in a 67 Camero. In the last 20 years it has been all Ford so I really don't know what I'm looking at. I can order a set of stock lenght pushrods and maybe find 1 rocker to match the set. The hardest part is tearing down the engine and scrubbing all the metal bits out of it. |
Sounds like a cheap set of pushrods were installed...? For performace apps the welded ends are whats really needed... I`m not real sure on the Procomp rocker are you sure they are not Proform...? Either way they kinda sound like a cheaper offshore brand... I`m sold on Crane or what I run now which is the Comp Pro Magnums (steel full roller rocker)... With a BBC the valve train has to be right or things such as your problems occur...
I was able to find Procomp in Canada. http://www.procompelectronics.com/ It appears they sell a line of knock offs. They even have a version of your crane stainless steel rockers. It all looks like pretty high quality stuff. I guess it is made in Austraila or South Africa because they have parts for Holdens which is their Chevy. I don't mind using high quality knockoffs. If I did, I would stay away from Walmart. My engine really does not see the high side of 4,000 RPM. It is in a T Bucket which is like driving a 4 wheel motorcycle. Stock rockers and pushrods would work fine cruising around the street though I have been known to smoke a ricer when necessary. I think a full throttle 1/4 mile or even 1/8 mile run would be pretty scary. I've been 160 in a quarter in my Fox Mustang but it had a cage and all safety equipment. I don't think I want to go there in my T even though it probably could be pretty quick. |
Well you might contact them directly and see about a single replacement...? Their stuff looks pretty good but without it being in the hand to really look at it then its hard to say...? If you can get a replacement rocker then do so and buy a good set of pushrods and with a cleanout as you mentioned... (would pull a main bearing cap or two and possibly a rod cap to check for bearing damage...?)
I will order a set of Crane street rod pushrods from Star Performance which is much cheaper and has better service than Summit and Jeggs. I am really dreading it but it must be completely torn down so I can run brushes through all the oil galleries and passages. If I don't do it right, I will never be able to go on a long cruise in it again. All I have to do is miss one chunk. |
If going that far I would just have it boiled...? Also I buy from these people and have had good luck...
I just came in for a lunch break. So far I've got it down to the point that all the lifters and bores are clean without a scratch. The cam journals and bearings are likewise OK. If I have it vatted they will have to install new bearings. I think I may use degreaser and a garden hose and high pressure air to clean it if there is no sign of damage. Now to run over to Northern or Harbor Freight and buy another engine stand. Last edited by Choctaw Bob; 04-15-2006 at 12:06 PM. Reason: another thought |
I would really like this engine to run at 160 with a thermostat just like my 67 BB Camero did. |
| Big Block vs Small Block Chevy | bigjoedo | Engine | 82 | 05-03-2010 03:36 PM |
| Swapping to big block chevy | low77ride | Engine | 5 | 09-15-2004 09:30 PM |
| Cam position in a big block Chevy | JamesRS | Engine | 0 | 07-19-2004 02:38 PM |
| Big Block in a 51' Chevy | oldford | Engine | 1 | 03-26-2002 06:32 PM |
| big block chevy fit in 1954 truck | pkaszuba | Engine | 3 | 01-03-2002 07:08 AM |
