Big block chevy question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2013, 02:37 PM
Hi guys, I wonder if you can help me with a question I have.
A friend bought a BBC for self and we are starting to buy their items, but watch your casting number is 10114182 and it says it's a tall deck, other say it and I want to make it a block 10 200 9800 or before start buying their stuff.
thank you very much
Old 02-28-2013, 05:45 PM
BOBCRMAN@aol.com's Avatar
Not a tall deck, at least the one I measured wasn't.
Visually, If the edge of the top water pump tapped hole is almost at the deck it's a 9.800" if it looks like 1/2" down from deck it is a 10.200"
A one piece seal 1992 block. Be careful with head/head gasket selection. Also be sure to balance final assembly.
http://i874.photobucket.com/albums/a...x/HPIM0203.jpg
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
aegserie2 (03-06-2013)
Old 03-01-2013, 08:55 AM
Hi Bob, thanks for responding!
today confirmed that it is a 9.80 and not a tall deck.
I have a dart block 10,200 in my house and put the engine intake my friend and does not reach the 2 head.
Bob, one more question, what is the problem with the head gasket?
thank you very much for the help!
Old 03-06-2013, 04:48 PM
bad news! the crank is cast
****! (okay that so? hahaha)
Old 03-06-2013, 05:25 PM
Not a problem! Unless you intend on building a 850 hp engine.
BBC cast cranks are plenty stout.
A problem with headgaskets only when trying to interchange Mark IV and Mark V heads. The water passages were changed and adapter gaskets are rquired to avoid coolant leaks.
Another problem that rears it's ugly head is the balancer and flexplate/flywheel, tho they look the same to the casual glance, are weighted differently. A IV balancer used on a V or VI will vibrate and kill bearings.
Old 03-06-2013, 08:23 PM
Hi Bob! thank you very much for responding.
We will be using a dart pro1 heads.
With respect to the harmonic balancer we buy a new one, unless we make a Strocker 489 and in that case would be internal balance.
With 650/700 hp are happy. In our tracks and no glue gets hard accelerate from 0.
sorry if not well understood what I write.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Big Block Chevy combination question JamesRS Engine 13 01-22-2011 07:08 PM
big block chevy piston to wall clearance question Ratoflic Engine 24 06-22-2006 04:16 PM
Big block chevy question bob cutler Engine 3 09-22-2005 08:48 PM
Big block chevy question??????!!!!!!??!!! bigbad66chevelle Engine 5 06-03-2005 08:51 AM
