Big block chevy question??????!!!!!!??!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2005, 04:23 PM
bigbad66chevelle's Avatar
Ok i have had 3 bbc and on all three of them the starters i have replaced and on all three the bolt pattern on the starter were the same theywere side by side now i bought a new boat and the starter went out on me so i went to replace it and and the bolt patter on this starter is staggerd at an angle. So i gues my question is that normal are there two style of big block chevy starters?????
Old 06-02-2005, 04:32 PM
poncho62's Avatar
Wiki Edits: 5
There is even one that has 3 bolt holes.......they are a truck starter, extra heavy duty if you can find one.
Old 06-02-2005, 08:25 PM
Bumpstick's Avatar
Hammer and a torch
Late model block Gen V or VI and you can use an SBC starter also... (late version)
Old 06-02-2005, 08:50 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
blocks
The older 400 sb also uses the staggered bolt pattern. I had to drill and tap a new hole for my mini-starter.
Old 06-02-2005, 09:08 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
The staggered bolt pattern starter is used with a 168 tooth flywheel. The straight bolt pattern starter is used with a 153 tooth flywheel. Both of these starters have an aluminum nose. There are 2 starters with 3 bolt holes and they both have a cast iron nose. One is designed to bolt to the block and the other to the bell housing. Depending on the year of your boat, it could have either the cast iron or aluminum nose starter on it. It is very important to use a marine specific starter as these are built to U.S. Coast Guard specs to retain any sparks that may cause an explosion in the enclosed environment of a bilge.
I hope this helps
Old 06-03-2005, 09:51 AM
Ya thanks guys i went and bought a starter last night bolted it up and she runs like a champ......
8.1L 496 vortec big block chevy, what is it? 406 ss monte Engine 20 11-03-2014 12:11 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Big Block Chevy Stroker Kit invincible Engine 3 11-11-2003 07:04 PM
Big block chevy need some advice abe Engine 2 12-16-2002 08:19 AM
Big Block chevy cam help deuce_454 Engine 4 05-20-2002 01:15 PM
