Big block chevy questions
Hi, I am new to this.
I have a few questions about some big block chevy parts i have, they are a bare block, a crankshaft and a set of complete heads, and they are all steel also if that helps. the first is 396 block with number 3902406 and date code of L166 and also partial vin number on it and can not decode it any ideas? The number is 10104 I V then a few of numbers i can not make out and then 5263. Any ideas of what car this is from? The second is a crank with the number 6223 on the front counterweight, and i can not locate the date code or the casting number for this any ideas of where the locations are? And finally the last is the set of heads with number 3904390 with L276 date code. But there is a number GM6T on the heads and was wondering what that meant? I know the block is from December 16th, 1966 and the Heads are from December 27th 1966, from reading other websites, I am just trying to narrow down on what vehicle these parts are from, any help would be greatly appreciated.
Hi
Welcome to Hotrodders.com Glad to have you with us Check out the knowledge base, should be ale to find all the info your after Rich Chevy engine block codes, casting numbers, and specifications |
Thanks for the help. I checked that link earlier and been thru almost every page and tried the mortec.com and that page did not come up for me for some reason. the closest i can get it that its a 396/325 hp motor was hoping to narrow it down even further.
Your heads are listed on this page. They show to be close chamber with 2.06 int an 1.72 exh.
http://www.chevy-camaro.com/chevy-ca...head-codes.asp |
Thanks. Been to that page and about 50 others in the past couple of hours trying to narrow it all done.
Crank shaft #6223 is a factory forged 396/427 crank
Heads 3904390 1966-67 396 325, 350 L-34/L-35 427 Closed 390, 400, L-36/L-68 98.4cc Rich |
'65 396 Impala 325 HP L-35 TH-400 4-Brl '67 396 Impala 325 HP L-35 TH-400 4-Brl '68 396 Impala 325 HP L-35 TH-400 4-Brl Quote:
I know you already found your answers, but I've used chevymania.com before. It has some good info too.
| questions on building a small block chevy | ATMRacerTX | Engine | 12 | 11-19-2011 10:18 PM |
| 301 block and 301 turbo block questions | transamdave | Engine | 3 | 07-19-2006 04:43 PM |
| 1968 Chevy Big Block labor questions | crownsapphire59 | Garage - Tools | 3 | 12-06-2005 02:02 PM |
| Chevy small block build up questions | ccnova | Engine | 5 | 02-06-2005 08:23 AM |
| questions about fuel system for a 434 small block chevy | tony350ss | Engine | 4 | 08-27-2003 11:02 AM |
