big block cyl. head casting - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 10:12 PM
i am trying to figure out what kind of heads these are. casting # is 8981068, so i can figure out what kind of plug to use. the first half inch of the plug hole is not threaded, only the bottom half is. it needs to be a long reach plug. i have not run across this before. these are possibly some aftermarket cast heads. thanks
Old 12-27-2011, 10:23 PM
BOBCRMAN@aol.com's Avatar
Old Champion "N" series plugs. The heads are 3931063 it is easy to read the 3 as an eight http://outintheshop.com/faq/casting/castings2.html or http://web.archive.org/web/200805160...om/castnum.htm
Old 12-27-2011, 11:01 PM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hello and welcome!
14102187 casting 305 head modification,outperform a 350 head ??? Calderone Engine 3 05-10-2009 10:09 AM
gm head casting # my87Z Engine 4 03-30-2009 03:43 PM
small block head casting #s JOE JOE Engine 5 01-23-2009 08:08 PM
need help with BBC head casting #'s 29 2dr sedan Engine 2 10-04-2003 10:58 PM
