Big Block Ford ~ 429 ~1971 Help With Identification Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2007, 04:50 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Question Big Block Ford ~ 429 ~1971 Help With Identification Please
Hey Y'all,
I stumbled across a Valve Cover attached to a Big Block Ford .
How can I Identify this Motor to make sure its not just a Valve cover?
I have become Moderately efficient on Small Block Chevy's & some Big Block Chevy's But these Old Beasts I haven't a clue.
Any & All Information Is greatly appreciated.
Main "Q"s
~How to ID Block & Heads.
~How to Verify the Year & possibly the make & model.
~What it might be worth.
~And any other pertinent info.
Thanks For Your Time
Rob
Name:	Picture 005 (Small).jpg
ID:	26058   Click image for larger version
Name:	Picture 006 (Small).jpg
ID:	26059   Click image for larger version
Name:	Picture 002 (Small).jpg
ID:	26060   Click image for larger version
Name:	Picture 003 (Small).jpg
ID:	26061   Click image for larger version
Name:	Picture 010 (Small).jpg
"SlowRide66"
"Illegitimis non carborundum"
Old 12-08-2007, 05:25 PM
boatbob2
valve cover.......
Hi,im not positive,but it appears that there is a Ford engine attached to that valve cover !!!!!!
Old 12-08-2007, 05:57 PM
onebadmerc's Avatar
I need a bucket of arc sparks
A easy way to tell what type of engine it is by a quick glance is....The 429-460 has the thermostat housing on the intake and has a cast aluminum timing cover like the SB 289, 302, 351W engines. If it has a two barrel carb, then it is most likely a 429 maybe a 370. Ford never put a two barrel on the 460. If the intake is under the valve cover and it looks like it is apart of the head, it is a FE. If the thermostat housing is on the block and has a stamped steel timing cover, with a 460 bell housing, it is a 351M or a 400. A 429-460 engine will have the casting numbers on a pad on the side of the block on the passengers side back by the bell housing. A FE big block will have the casting number on a pad on the drivers side up by the front of the block. All 429-460's will have a 460 cast on the front of the block on the drivers side. Most FE engines will have a 352 cast on the front of the block on the drivers side, some won't have a number cast at all and some will have a backward 105.
Old 12-08-2007, 07:00 PM
woodz428's Avatar
Troll Hunter
It is a 429/460 from the pics... the problem is that the 429 was only around a few years in cars and then became the 460 (which had always been in Lincolns) and they were available during the same years. They also share many casting #'s. The stamping on the dist..may help, but it probably has a V Lincoln code. I am afraid that you may have to pull the pan and get the crank # to determine which it is. Either one is a good start for a big engine. A 429 is easily converted to a 460, so that shouldn't be an obstacle.
Old 12-08-2007, 07:55 PM
Jmark's Avatar
I'll take it!!! I'll take it!!!! Pretty please!!!! LOL
Mark
Old 12-10-2007, 06:55 PM
Rob Keller's Avatar
Wiki Edits: 38
Question
I was talking to a buddy of mine who said to look for #'s on the heads by the spark plugs
So I did its D3VE A1A
What dose this mean
Good bad indifferent?
It got too dark before I remembered to go look @ it ...again
I will try to look @ the Block & find #'s
Thanks for all the replies
R
"SlowRide66"
Old 12-10-2007, 07:15 PM
onebadmerc's Avatar
D3VE heads are 92 cc low performance run of the mill 70's 429-460 heads.
Old 12-10-2007, 07:38 PM
nitro_baller4692's Avatar
floppers forever
if it was worth any real value this is what you would want to look for.
http://429mustangcougarinfo.50megs.com/components_3.htm
Old 12-10-2007, 09:58 PM
woodz428's Avatar
Troll Hunter
The D3VE # illustrates my comments regarding shared casting #'s. Since it is a 1973 casting #, it becomes more likely that it may be a 460, although a crank # will be the only way to be positive. There is also a casting date,usually a 3 digit # like 3M14 whereas the first # is the calendar year (the casting # excludes 1963, but it could be 1983), the second letter is the month (Jan=A,Dec=M, I is not used) the last 1 or 2 numbers are the date. So the code given would be Dec 14, most likely 1973.....the A1A suffix indicates a change in the casting at some point, but the heads were used in 1973-74. If the heads haven't been changed out at some point it appears that it is a 460. the same casting #,date code on the block can tell you when it was cast. At the time, it was common for heads to be swapped when a valve job was performed instead of having the heads done, a time saver mainly, so the heads could have been installed on a earlier 429 when it needed a valve job. The block casting #s can narrow it down, and the crank # will of course confirm it.
Old 12-11-2007, 04:42 AM
aka Duke of URL
The VECI Decal identifies the engine as a 1971 429. The D3VE-A1A heads are 1973/ closed chamber low compression heads.
You need to find the block, intake manifold, water pump and any other visable (DIST-ALT) stampings for year of assembly. The stoke needs to be verified by piston travel.
Name:	VECI Decal_2.jpg
ID:	26090   Click image for larger version
Name:	VECI Decal_1.jpg
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 08:26 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 01:37 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
302 Ford Small Block Identification Drean Engine 6 08-08-2005 02:19 AM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 08:06 AM
