Big Block Ford transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2012, 07:02 PM
I plan on building a Cobra kit and need info on transmission choices. Can I use a 5.0 5 sp? Does the tranny have to be big block only? The engine is a 390.
Old 02-17-2012, 07:18 PM
Wiki Edits: 31
You could bolt a T5 to a BB, but even a stock BBF will eat that trans.. T-56, or a TKO 5spd will hold behind a BBF
1936 ford V8 engine & transmission in 1931 ford JB1931 Hotrodding Basics 3 01-22-2012 10:05 AM
1934 Ford transmission with1948 Ford truck engine clutch questions ppetrano Transmission - Rearend 1 05-20-2011 11:02 AM
Ford "Y" Block and a later C4 or C6 Transmission RAW Transmission - Rearend 6 04-02-2006 08:01 PM
How to disengage transmission from block? El Raton Transmission - Rearend 10 11-26-2005 07:55 PM
Chev 400 Small Block & Manual Transmission JohnT Transmission - Rearend 4 10-03-2002 06:58 PM
